S2000 Body and Paint Body kits, paint, ding repair and related discussions
Ap2 Mugen Style Lip on AP1
Old Jun 5, 2011 | 03:12 PM
Righteous_Spec's Avatar
Default Ap2 Mugen Style Lip on AP1
From what I can gather the Mugen style Ap2 Lip only uses bolts on the underside of the bumper. I myself own an Ap1 and none of the ap2s in my town are driving around with a Mugen or Mugen Style lip.
I found a picture in a form and function thread that appears to be what I am trying to do. (If this is not a ap2 mugen style, does anyone know what it is?)
I would be grateful for any feed back or thoughts. Pictures of ap2s with Mugen lips from the underside, or mounting locations of a mugen style lip.
Thank you much.
Old Jun 6, 2011 | 01:08 AM
xoz's Avatar
xoz
I think it looks great on AP1, mounting point is central between the scoops, but you can virtually add mounts where you like, especially if its a urethane replica. Have a look at Evasive Motorsports web page and you'll see one off the car, from this you'll be able to tell how easily this will fit to AP1.
http://www.evasivemotorsports.com/me...0_Aerodynamics
Old Jun 6, 2011 | 09:10 AM
kevos2k's Avatar
test fit it on my car a while back.. it does not easily bolt up to the AP1 bumper... and looks better on the AP2 IMO
IMG_1132.jpg?t=1243283017
Old Jun 13, 2011 | 08:06 AM
irmos2k's Avatar
I agree it looks really good on the Ap1, I have both the Ap1 front and Ap2 front as well as the rears, and I can never decide which one I like better, however I want the Mugen ap2 lip on the ap1 bumper and I either want the amuse r1 style front lip for the ap2 or the CR front lip. still so many decisions. From what I've understood and read which I have read alot about it, it's not a direct bolt up and you do have to drill holes to get it to fit, however if installed correctly it looks sick, I had the picture at the top as my background for along time because i like the look so much
Old Jun 19, 2011 | 04:42 PM
poop-dog's Avatar
Even on my ap2 it didn't line perfectly up. I also drilled some holes bc it was just harder to access where they wanted it bolted up. Its all plastic so you shouldn't have a problem. Expect about 2 hours taking your time. Bolt up the 2 sides then prop up the middle, I used my belly, then just drill and bolt up.
i didn't like the hardware either so I had to make a run to Home Depot for replacements.
Old Nov 23, 2011 | 02:03 AM
kryptonite's Avatar
Member
Spotter
Dont mean to bump a semi old thread. Just bought the lip off someone on this forum but it didnt come with the hardware. Anyone got the specs of the bolts I'd need?
Old Nov 23, 2011 | 02:45 AM
jonmizu's Avatar
I believe it was 8bolts out of the 9 that have been predrilled will fit directly only 1 of the middle front ones will not have anything to line up to and the furthest left and right holes you will have to drill your own hole into the bumper. I took one of those silver clips (not sure what it's called ) that the under panel gets drilled into and shoved those into the sides so I I wouldn't have to use a nut (makes the whole install easier
Old Nov 27, 2011 | 03:43 PM
Jmocustoms's Avatar
I beleive I used 10x1.5 probably 40mm long, and I used 9 of them. I also made custom diffusers to go on mine though. The only hole that didnt line up was the middle, the the ends have to me custom drilled, brackets made, or use speed nuts of some sort.
Old May 17, 2012 | 03:29 PM
Hondaplease's Avatar
Reviving an old thread!
Hey mate, i'm looking into buy a new front lip for my ap1 bumper and i saw your example of this and i must say it looks fantastic.
Just wondering if you can post some more pictures from different angles?!?!
I would like to see how it looks before i take the plunge and buy one!
Many thanks,
Old May 29, 2012 | 02:19 PM
MySpaceTOM's Avatar
i really like this as well! would like to see some more detailed pix also
thanks in advance!
EDIT: went to Google and found some stuff.
this thread
https://www.s2ki.com/s2000/topic/830...nt-lip-on-ap1/
always up for some more detailed pix tho
skylinrcr01
Sep 2, 2013 04:26 AM
s2000 gib
Dec 4, 2009 11:48 PM
sIIooo
Jan 3, 2009 04:10 PM
SojuSoulja
Sep 24, 2006 10:32 AM
Ws2006
Feb 7, 2006 09:04 PM
