S2000 Body and Paint Body kits, paint, ding repair and related discussions
Disassemble light tail
Old Jan 29, 2014 | 01:18 PM
Nicroman's Avatar
Default Disassemble light tail
Hi guys.
This is my first post, I do not know if it's the most appropriate place for this, but here goes...
I wonder if it is possible to disassemble the rear light of my Honda S2000?
You can unmount the plastic headlight? I say this because inside the lighthouse has land and as such wanted to disassemble for cleaning.
Regards.
Old Jan 29, 2014 | 02:55 PM
thait's Avatar
yes it can, I have to modified it and add led to my AP2 Tails. But to tell you the truth it is not easy and you can risk cracking the lense if you arent carefull. It will take some time and you will heat up the butyl around the tail lights to open it up
Old Jan 29, 2014 | 03:02 PM
Nicroman's Avatar
Thanks for the reply.
I do not want to switch to AP2.
I just want to clear my tail lights.
How do I remove the tail lights lense?
Old Jan 31, 2014 | 01:18 PM
Nicroman's Avatar
can anyone give some more opinion?
Old Feb 1, 2014 | 12:33 PM
wisdom's Avatar
You can either bake them to soften the glue and pry it open. Or use a heat gun and pry it open as it softens.
Very time consuming and messy job. When resealing make sure it's 100% sealed or you'll get condensation inside.
Old Feb 6, 2014 | 08:35 AM
thait's Avatar
Originally Posted by s2ka
The tail lights are not bonded together like the headlights. The plastic is fused together, you can't just heat them up. You would have to cut them apart, very easy to crack them.
Try doing it on a used or damaged one first.
You sir are WRONG. have you done this first hand? They are NOT fused together. I did a set of oem ap2 and it is for sure bonded like headlight. its just harder to do but definitly doable. I have my ap2 all modded out waiting to get installed once my car goes into the shop. please dont misinform users on here
Im going to attept the ap1 tail lights eventurally.
I do however agree with you on trying on a use set first. The lense is fragile and does take a bit of force/patients to do
Old Feb 8, 2014 | 05:26 PM
s2ka's Avatar
Oops, you're right. I was thinking of my Prius tail lights. They're fused together and I cracked one trying to get it apart.
Old Feb 28, 2014 | 04:11 AM
adamjgriffin's Avatar
Iam also interested in this as my rear AP2 tail lights have dust and dirt inside the lenses and I would love to clean it out. I was wondering if a good plast of compressed air around the lens would be enough to force it out. If the dirt and sand got in it has to come out somehow...
May 10, 2015 02:54 PM
ans2k
Nov 28, 2011 07:17 AM
Josh_With_The_S2K
Jan 24, 2008 01:10 AM
falcone
Jul 21, 2006 07:00 AM
lamvu
Dec 20, 2004 10:13 AM
