S2000 Body and Paint Body kits, paint, ding repair and related discussions
Driver side door not flush
Old Apr 4, 2010 | 11:08 PM
cu@8k's Avatar
Default Driver side door not flush
i have found one topic from 04 that had the same issue but there was never a clear answer to why or how to fix the door, or if its a simple bolt to be tightened. need help, any links or suggestions?!
Old Apr 6, 2010 | 04:48 AM
blueducatikidd's Avatar
curious to this as well..
Old Apr 6, 2010 | 11:40 AM
Vanishing Point's Avatar
Pictures, or a better description of where the door is misaligned would help diagnose the problem. It can be one of several things depending on the door position, has the vehicle ever been in an accident?
Old Apr 6, 2010 | 03:26 PM
cu@8k's Avatar
i am unable to upload any pics right now, but i just purchased the car on sat the 3rd and it was a clean title, no accidents. i noticed that the door was poking out the most right before the bottom of the door ends and the side skirt begins. its also not quite even at the top of the door where it seals. i really hope the seller didn't lie abt his "clean title".
Old Apr 7, 2010 | 04:44 PM
thatk20vteck1d's Avatar
I got screwed where a seller lied about his clean title..my fault i didnt look though. Everything is fine, cept i need a new front bumper and headlight. Drives fine
Sorry i dont have an answer for your problem, best of luck!
Old Apr 8, 2010 | 03:11 PM
cu@8k's Avatar
it's fine, and yeah same with me, my fault if so, because i didn't check as well. drives fine, but wen im parked i just wish it was perfect, and the door is keeping me from feeling 100% satisfied lol, and btw ur car looks just like mine, same wheels, color, and removed s2000 badge.
Old Apr 12, 2010 | 03:12 PM
LuDawg's Avatar
I had the same thing on MY03 and what worked for me was was unscewing the hook that is attached to the body of the car and turned it around so that the back screw is now in front. I hope this makes sense.... Might be worth a try since it's only two screws
LuDawg
Old Apr 16, 2010 | 03:40 PM
cu@8k's Avatar
ohh i think i kno wat ur tlking about... the hook that the lock goes around? and thanx for the help!
Old Apr 19, 2010 | 09:11 AM
LuDawg's Avatar
Yeah, the steel hoop that is held in by two srews that the door locks into when you shut it.
ICATCHER
Aug 31, 2016 03:30 PM
krnmike
Mar 28, 2010 12:59 PM
s2konroids
Jun 1, 2009 03:18 AM
killereclipse
Apr 22, 2007 06:50 PM
