S2000 Body and Paint Body kits, paint, ding repair and related discussions
Headlight adjustment (again)
Old May 12, 2013 | 11:49 AM
SupermanZ11's Avatar
Default Headlight adjustment (again)
Hey everyone,
Backstory: I recently swapped my AP2 OEM headlights for a modded OEM set courtesy of Euroboutique (aka S4play). Recently I finally had an opportunity to drive at night and I noticed that the headlights "didn't work" the same. (They were misaligned) Doing some research, I found various threads on headlight adjustment and was able to adjust one side only so that there is that sharp cutoff that we all love about the s2k headlight. (I did the adjustment so that the right is slightly higher than the left.)
The issue that I do have is that the left side will not adjust any lower. When trying to adjust it, it does adjust higher but won't go lower after so many turns on the adjustment gear. Right now when I do drive at night, I do notice that the headlight cutoff is slightly above the trunks of cars in front of me and I've also noticed that signs are illuminated from a pretty good distance (which is a good thing on a dark road). Although I haven't been "high beamed", yelled at or even flipped off, I would like to be able to lower the headlight at least another 1/4 inch or so. I've done some research here on the forums and online and couldn't find anything about the headlight not being able to be adjusted any lower. Does anyone have any insight?
Thanks in advanced.
Old May 17, 2013 | 04:29 PM
bump
Old May 17, 2013 | 04:49 PM
sillyboybmxer's Avatar
the best advice i can give you with this is to go to a building at night, one that you can see the beam on well enough, so a flat wall is good, not that weird metal type of wall with ridges all over it like found on industrial buildings.
Break out the tape measure and measure 25ft out from the wall and park your car at that point(i am sure you read this already), but you should see that your light should/and does not need to be lowered any more than it is, it should be raised,...unless this modded set you have messed with the internals and its not the same anymore.
Set the left side/driver side to the D.O.T standard of 2" below the center of your headlights height(measuring the lowest part of the beam,..because each beam has a small step) . For example, if you measure from the ground to the center point, and it's 25", the drop of the beam should be 2" at that point of 25ft from the wall. So the top of the drivers beam should be 23". AND in order to do this right, you need to cover the passenger side light up with a jacket or something so you can see the beam on the wall. Mark the wall with a pencil or piece of tape so you can go back to the car and in your case RAISE the beam as I am sure it is way to low right now.
Lots of this is probably just something you already read but you should not be all the way out of adjustment to the low or the high end if its done right...even if lowered 4 inches as the light beam doesnt change enough unless you raised your rear of the car a foot into the air and left the front sitting on the ground lol
And from there, once you get the left side done, you can raise/lower the passenger side to be 2" higher than the drivers side so it hits the road signs like intended. This is what will give you the nice "step" in the cut off people talk about. When they are misaligned you wont be able to see it. Hope that helps some.
Old May 18, 2013 | 07:40 AM
Thanks for the reply. I have come across other threads about measurements from the center of the headlight vs the top of the beam and adjusting as needed. I have adjusted the right side to coincide with the left side based on the lowest the adjustment the left side will allow. The issue that I have is that the left side doesn't lower any more and since the swap, it appears that the beams are illuminating things higher than what I remember before the swap. I do have the defined "step" in the beam pattern. In speaking with S4play about the modding process, nothing more is done with the headlight housing besides opening them up for the clear swap and the R8 LED installation. I just want to know why the headlight cannot be adjusted any lower unless it is at the lowest setting already.
Old Jun 13, 2013 | 05:10 PM
After getting high beamed by another driver and getting pulled over (and got away with a warning for the headlights being too high), I decided to go back to S4play about looking into the issue. As it turned out, there's a clip that was missing the adjustment screw binds to for raising and lowering the projector. Somehow it popped out. This required re-opening the housing and reattaching that clip so that proper adjustment can be made. Kudos to S4play for helping out with this!
OriginalSoCal
Aug 3, 2016 07:36 AM
ungucpho
Feb 6, 2013 05:06 AM
SilverS2kF22C1
Mar 30, 2010 06:30 AM
s2kdriver80
Mar 5, 2010 09:45 PM
lucksack
Jul 10, 2007 07:45 AM
