Help with Colgans Customs Bra, won't fit right
Hey all, I purchased a used colgans customs bra for my S for racing (trying to save the front end from road rash). I tried to put it on this past weekend with major issues. First, does the hood latch need to be adjusted? With both sections of the bra adding two layers of material between the opening I'm assuming you need to adjust the gap here? Also, the last (top) hook at the fender, where is this supposed to attach as I can't see anywhere to attach it that would keep it taught. Also, I'm assuming you have to either sneak it in between the inner fender piece and the metal fender or remove some of the inner fender clips to facilitate easier installation? Thanks for any help on this.
For anyone that has one of these and has trouble putting in on here is how to do it. I was able to get the factory installation sheet but that was no help. The key is to put the top most fender hooks on first while the center section of the bra just hangs loose of the nose. Remove the clips from the inner fender well piece, install the bra hooks, then put the fender clips back on. From there you can pull the bra down and install the center hooks then move out and finish up with the lower bumper/fender hooks.
