S2000 Body and Paint Body kits, paint, ding repair and related discussions
How to flush boot
Old Mar 17, 2013 | 01:08 AM
e130dan's Avatar
Default How to flush boot
Hey. I'm having my boot sprayed on the 6th april and want to loose the lock and H badge before.
So what's the process in doing it? I was thinking of welding a plate behind the holes and then cut some metal to fit in the holes and weld it up. If this is correct way to go do I use same thickness metal as boot or thinner so that I can get filler over it?
If this isn't the best way please advise on the. Est route to take
I won't be doing the welding myself my friends dad to do it.
Regards. Dan
Old Mar 17, 2013 | 03:03 AM
kryptonite's Avatar
Member
Spotter
You don't need to weld anything on there. Here's a good DIY to follow
https://www.s2ki.com/s2000/topic/839...-bumper-holes/
Old Mar 17, 2013 | 05:10 AM
e130dan's Avatar
But that's for plastic. Isn't a different procedure for metal?
Old Mar 20, 2013 | 12:31 AM
realblag's Avatar
The two little holes behind the H badge can just be welded up. The lock hole can be done the way you were thinking. A piece of metal welded from behind and a washer or something welded to the frontside to fill the hole. If it is too thick and sticks out, you can just tap it inward with a hammer until it is just below the surface of the boot(trunk) lid. Regular body filler will finish the job.
s2konroids
Sep 9, 2013 01:06 AM
it'S2klean
Jan 27, 2011 12:41 PM
ff_mark
Feb 5, 2006 11:52 AM
nickrg3
Apr 8, 2005 04:00 AM
MacGyver
Oct 18, 2000 03:33 PM
