S2000 Body and Paint Body kits, paint, ding repair and related discussions
how would you fix this?!
Old Oct 13, 2010 | 12:21 AM
kidtofuu's Avatar
Default how would you fix this?!
how would you fix that besides covering it up with side skirts?
Old Oct 13, 2010 | 07:12 AM
stickyfingers's Avatar
A body shop should be able to pull out the damage and reshape the metal, with a little bit of filler it should be fixed.
They also could get away with just painting the bottom part of your rocker panel as berlina black is a solid color(they wouldn't need to blend the quarter panel and front fender)
Old Oct 14, 2010 | 05:20 AM
lfjchau's Avatar
i got the same problem.
and the shaved line under the door, front the of rear wheels cracked a bit.
is the crack fixable?
Old Oct 14, 2010 | 07:12 AM
WarTowels's Avatar
Sand down a strip in the paint, weld a tab to the metal, use a puller to pull the dent, cut the tab, use a little filler as possible to return it's shape. Repaint and blend.
-Towels
Old Oct 15, 2010 | 07:58 PM
Bryan858's Avatar
-Towels
Old school way is to drill a couple small holes and pull it out then use bondo to fill and blend. You can do it yourself if you have the time. Just paint the lower portions on both sides and no one will know the difference.
Zerolagoon
Feb 10, 2016 08:46 PM
chrisn
Mar 31, 2007 06:23 AM
JSfetko
Mar 12, 2006 08:40 PM
Squeezer
Feb 24, 2003 01:03 PM
purdue2k2
May 10, 2002 04:10 AM
