Removing Side Emblem Adhesive
One of my "S2000" Badges came off and I'm looking to remove to black glue/adhesive that remains before I put my new emblem on.
Best way to go about this?
Thank you.
Thank you.
Its expensive, but 900 Pre-Kleano is amazing.
You may be able to find a smaller container for cheaper.
http://www.thepaintersedge.com/paint...kleano-gallon/
I just made some phone calls and found out an Epoxy was used..gonna bust out the blow dryer. lol
Mine was horrible to get off. Literally took an hour of just heating spraying with goo gone and wiping. Finally ended up just leaving it alone as I was having my car sprayed in a few weeks and it just got sanded off. The "h" emblems on the other hand popped right off with no adhesive under them.. Go figure.
I've been through this nightmare. You will NEED a heat gun. Not a blow dryer, an actual heat gun. And be warned, once you take the emblem off, you will have a hideous "s2000" shadow on your fender. I have buffed and buffed and it will not come off. Complete respray coming for me. Don't do it
I use this, got it at OSH. No longer available in California. Test an area to make sure the clear coat is okay first.
1. Chemical Identity CAS No. 78-93-3
Methyl Ethyl Ketoneor MEK
Other Names:
Ethyl Methyl Ketone
2-Butanone
Methyl Acetone
2. Product Uses
MEK is a liquid solvent used in surface coatings, adhesives, printing inks, chemical intermediates, magnetic tapes and as dewaxing agents in lubricant base oil production. MEK also is used as a solvent for fats, oils, waxes and resins. It is a highly efficient and versatile solvent for surface coatings. Because of its effectiveness as a solvent, MEK is especially valuable in formulating high solids coatings, which help to reduce emissions from coating operations. Consumer and commercial applications include:
• Lacquers for automotive/furniture finishes
• Coatings - epoxies, urethanes, cellulosics and vinyls
• Printing inks
• Adhesives for PVC pipes
• Resin thinners and clean-up operations
• Reaction/Extraction solvent for pharmaceuticals
3M also makes a good spray adhesive remover.
Other Names:
Ethyl Methyl Ketone
2-Butanone
Methyl Acetone
2. Product Uses
• Printing inks
