Sponsored by: Sake Bomb
ABS / Wheel Speed Sensor Fail?
Old Sep 29, 2020 | 10:22 AM
jtgray10's Avatar
Default ABS / Wheel Speed Sensor Fail?
My ABS pump is cycling when speed drops below ~10 mph.
No ABS light.
I think one of my wheel speed sensors is shot, how do I figure out what one it is with a multimeter?
I've checked resistance across all of them and get around 1.3 kOhms
Voltage from the ABS module is consistent.
All the tone rings seem to be in decent shape with no missing teeth.
Any suggestions are appreciated, the sensors are expensive so I'd like to have confidence that I am replacing a bad one.
Thanks
Old Sep 29, 2020 | 10:47 AM
flanders's Avatar
You can spin the wheels and measure voltage output from the sensor, just check for consistent readings.
Disconnect the big connector at the ABS module and check from there.
Check this post for pinout https://www.s2ki.com/forums/s2000-un.../#post24563726
Old Sep 29, 2020 | 01:53 PM
jtgray10's Avatar
Excellent, thanks for the link. Didn't show up on my previous searches for some reason.
Those pin-outs will be much easier to access than the individual wheel speed sensors.
SakeBomb Garage
15
Nov 30, 2023 12:27 PM
SakeBomb Garage
May 28, 2019 07:55 AM
Hargreaves
Apr 13, 2016 12:22 AM
