Sponsored by: Sake Bomb
AP2 alignment specs?
Old Feb 2, 2010 | 06:40 AM
Black Knight's Avatar
Default AP2 alignment specs?
Does anyone have the Honda recommended alignment specs for the AP2? (search is down so I couldn't use that function)
Old Feb 2, 2010 | 08:07 AM
GPW AP2's Avatar
Not sure of the specs, though if the search is down you can search from google.com by entering the info below.
alignment specs site:https://www.s2ki.com/forums
John
Old Feb 2, 2010 | 09:06 AM
SilverS2kF22C1's Avatar
Specs I plan on aligning the car to in the spring.
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0
rear toe 0.20 total 0.40
Old Feb 2, 2010 | 09:23 AM
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0
I'm just wanting to align to US specs....anyone know those?
Old Feb 2, 2010 | 10:22 AM
camuman's Avatar
pretty sure the only difference is that US spec is 0F -1R for camber, all else should be the same.
regardless, the alignment shop will have the us specs. i persoanlly run us spec even though i run huge tires and lowered. i hate the uk spec. extra camber recked tires unevenly.
Old Feb 2, 2010 | 10:40 AM
exactly why I don't want to run UK spec
Old Feb 2, 2010 | 10:48 AM
spets's Avatar
AP2 spec has only .25 total toe, not .40-.5 like AP1/UK spec.
I run UK spec camber but US AP2 spec toe.
Old Feb 2, 2010 | 10:50 AM
How long would you all wait to get an alignment done after installing lowering springs?
Old Feb 2, 2010 | 11:01 AM
rail157's Avatar
Are you sure you didn't have some other problem with your alignment somewhere? An extra degree of camber should have a negligible effect on your tire wear, unless there's an underlying problem.
Old Feb 2, 2010 | 11:29 AM
ZDan's Avatar
2* camber is no big deal. Excessive toe causes a lot more wear than modest camber, mine's maxed out at 2.2* in back and the rears wear evenly across the tread.
