Sponsored by: Sake Bomb
bbk fitment question
Old Feb 4, 2011 | 01:58 PM
Rdragon's Avatar
Default bbk fitment question
what bbk would fit with these rims?
http://www.racinglab.com/rota-d2-s2000.html
Old Feb 5, 2011 | 12:20 PM
Rdragon's Avatar
anyone?
Old Feb 5, 2011 | 07:39 PM
BowlofRice's Avatar
depends on which big brake kit you want.
Old Feb 5, 2011 | 07:57 PM
BrakeExpert's Avatar
The Brembo GT kit ought to work, as would any Wilwood kit with less than 13" discs. The rotora kit should also work.
Side question. What the hell happened to that Aston Martin in your sig?
Old Feb 6, 2011 | 03:20 AM
AusS2000's Avatar
That's a One-77.
http://www.astonmartin.com/thecars/one77
Old Feb 6, 2011 | 08:01 AM
1nate7's Avatar
You might have issues fitting any BBK. I can't exactly answer the question, but the fact that 17" D2's don't even clear the stock brakes is not a good sign. If you already have the wheels you can print out a Stoptech template and check.
Old Feb 6, 2011 | 08:09 AM
Rdragon's Avatar
they are 18's i know the rotor would fit im worryed about the caliper
Old Feb 12, 2011 | 09:18 AM
skillman11's Avatar
I have those wheels and the offset gives lots of clearance for the BBK, it also will make the tires rub.
I rolled my fenders and installed KW V3 coilovers that helped the rub, but i still get a little every once and a while. If I were to increase the bump setting to make it a stiff ride, they likely would not rub but it would be a bouncy ride.
Let me see if they fit over my Rotora 4 piston calipers on my track car.
clarkster009
Nov 22, 2011 01:37 PM
project jdm queens
Jun 19, 2011 10:43 AM
PeanutButter
Mar 4, 2008 11:08 PM
cordycord
Nov 27, 2007 07:24 PM
sjay
27
May 16, 2006 04:50 AM
