Sponsored by: Sake Bomb
Bent front control arm? Camber/caster adjustment problems.
Old Aug 14, 2014 | 08:08 AM
james0933's Avatar
Default Bent front control arm? Camber/caster adjustment problems.
Hi guys, i tried to do an alignment today, but i simply cannot get the front passenger side camber lower than -0.8. I also cant get the caster lower than 9.1. I shifted the subrame a little and that did help, but its still off.
Any ideas?
Old Aug 14, 2014 | 08:31 AM
trackit's Avatar
Have you looked at the upper arm? If the rear section of the arm is bent you will get more camber and caster.
Old Aug 14, 2014 | 09:10 AM
james0933's Avatar
I havent, but will! Thanks!
Old Aug 14, 2014 | 09:16 AM
macr88's Avatar
The knuckle is what usually bends, if you can measure the distance between the upper and lower ball joint and compare it with the other side you might find a difference between the two measurements.
The other part that bends is the rear mount (caster adjustment) of the lower control arm.
Old Aug 14, 2014 | 09:31 AM
trackit's Avatar
What were the included angle measurements? What happened to the car? Yes knuckles bend but with that much of a difference in specs you would think that the tire would be against the knuckle or close to it.
Old Aug 14, 2014 | 09:45 AM
james0933's Avatar
The subframe part? Before this alignment i installed the energy suspension bushings in the lower arm, but only 2 of the 3. I didnt do the camber bushings because they looked good and strong.
The included angle adjustments wernt included. All i know is that the camber cant be adjusted for less than -0.08 and caster less than 9.1.
They were able to adjust the driver side caster to 8.2 and camber was able to get to -2.5.
Old Aug 14, 2014 | 09:56 AM
trackit's Avatar
ok so before the bushing install the alignment was square? (good) and after bushings not good? What spec are you trying to get to?
Old Aug 14, 2014 | 10:59 AM
james0933's Avatar
No, i replaced the bushings because one was torn. So i fugured id just replace the other ones that looked questionable. I didnt bother with the camber ones because they looked good.
This is the first time trying to align it. I bought this s2000 strictly as a track vehicle.
I do remember when taking the control arm off, that the shock was blown on that passenger side and a non oem bolt was used for the lower shock bolt. Maybe something is bent?
Old Aug 14, 2014 | 11:00 AM
james0933's Avatar
Id like -2.5 camber on each side and max, but even caster side to side.
It seems crazy that i have 8.2 and 9.1 caster lol
Old Aug 14, 2014 | 11:31 AM
macr88's Avatar
Loosing 2-3° at the wheel isn't going to be much of a bend at the knuckle or control arm.
Good luck with finding it.
