Best brake fluid 2016
So a company like torque rt700 advertising there brake fluid like the best out there with lab test i me i ask what is the best and is stupid ? Is simple question the best brake fluid for all track , street , durable best pedal feel best to resist boling on xtreme conditions bla bla bla to me best is mean = (mejor) is like went you ask what is best gold or platinum is a simple question
To answer your example:
Neither Gold or Platinum are THE BEST because there may be one application that requires the properties of one or the other.
For example: gold is more conductive than platinum. Why don't they use it in spark plugs? Because platinum melts at a higher temperature and is more resistant to corrosion, and is more dense.
So if you needed a wire conductor that was used in a house...gold would be the best of the two choices. It is a better conductor and its cheaper and more malleable.
If you need a spark plug conductor, platinum would be the best of the two.
For the record, my first post was a follow up question to find out what you meant by best.
There is nothing that's the best for everything. Nobody can answer your question.
For different uses and environments, different brake fluids will be the most advantageous.
Find out what properties you need for YOUR purposes. Then buy the brake fluid that best suits that.
IDK why I'm typing this. Nevermind.
TrumpetTitan (08-14-2019)
As a noun I like tiger, as a verb I prefer wrench....
To the OP:
The primary considerations for high performance brake fluid are; DOT type, wet and dry boiling point, hydroscpoic properties, viscosity and of course price. There are others depending by application but this should get you started. Also start with what the OEM recommends if DOT 3, then both 3 and 4 are options. Here is a nifty brake fluid comparison chart.
https://www.lelandwest.com/brake-flu...ison-chart.cfm
To the OP:
geoffrey farrugia (02-12-2020)
Como ellos dijo, lo mejor es lo mejor para tu uso. La repuesta es diferente depende en tu necisidad.
Pero, el wet boiling point es problamente lo mas importante. Pero los que tienen lo mejor, algunos veces son mas hygroscopic. Ellos absorber agua mas rapido. Muy mal. Necesitan cambiar frequentemente. Ok para racecar, pero no para el calle.
Problamente cualquier DOT4 brake fluid es facilmente disponible en tu area desde tienda de autoparts es mas de suficiente para tu necesidad.
Buscen por uno que es disponible, barato, y tienen un alta wet boiling point, pero no es muy hydroscopic...
ATE...not the best, but best bang for the buck, which makes it the best.
