Blox Steering Rack Ridid Bushings - Cracked Bracket
I installed Blox rigid steering rack bushings the other day and found that they were a really tight fit. I'm not sure if I over torqued them down or if they simply were just to large. Anyways this was the result.
Blox solid bushings in but not fully seated.
Damn.....
Anyone else experience this issue?
Damn.....
Expensive
The bolt on bracket is the one that cracked. I found a replacement on eBay for $40. I guess I'll have to ream out the hole or reduce the bushing size before reinstalling.
The ones I got from ballade just slid in (no press fit).
Did only 1 have to be pressed?
Idk about anyone else...but I kinda worry about what would happen if the wheel got impacted.
Think I would get a micrometer out,get all costs refunded from the vendor +And All costs inc...+ an engineer report if needed.
Damn.....
Damn.....
The bushings were installed in the correct locations. Just sharing my experience.
I'm not all that sure that the crack would have any influence anyways since the bushings are solid and I also have the CR rack braces that bolt down on top.
