Which brake fluid do you use?
Thinking about flushing the brakes before DBR.
First off, how much am I going to need to flush the whole system (gravity flush per the stickies...thanks Bill for the instructions)?
Heard good things about ATE Blue DOT 4, but should I just use Honda DOT 3? What are some other high-quality options?
Superblue is good but Valvoline dot3/4 is about $7 / quart at advance auto its not far off:
Dry ERBP F 503
Wet ERBP F 343
http://www.valvoline.com/products/br...brake-fluid/28
ATE® Super Blue (DOT 4) has a dry boiling point of 536F and a wet boiling point of 396F.
Dry ERBP F 503
Wet ERBP F 343
Why would water ever been present in the system?
WET BOILING POINT
The minimum temperatures that brake fluids will begin to boil when the brake system contains 3% water by volume of the system.
DRY BOILING POINT
The temperatures that brake fluid will boil with no water present in the system.
DRY BOILING POINT
