Brake in procedure - for changing pads and/or roto
but it's 25 minutes long lol, ok ok, i'll watch it now
edit: nice vid but very long winded, they should really get some cliffnotes or something, i think everything could have been said in a page or two of reading...
Originally Posted by theblackpearl,Feb 16 2010, 05:57 PM
to zdan: if "it's all coefficient of friction and clamping force" that stops the car, then what causes the loss of braking force during initial break in... surface area is a variable, at least according to all the physics that i've learned
Ff = Fn * c.f.
Frictional force = normal force times coefficient of friction.
Yeah, that is a simple model, but in the case of new pads on a worn rotor, at normal temps, it's going to hold. There may initially be a lower c.f. with new pads/old rotor, but once pad/rotor c.f. is established (usually only a couple of ~30mph stops for me with street pads), you'll get the same braking force per pedal effort well before you've got full pad/rotor contact.
Originally Posted by rob.ok,Feb 16 2010, 08:28 PM
Anyone watch the video I posted. I've read up on this issue quite a bit, but I still learned a thing or two from that video. It's done really well for what it is.
Super educational vid. Kind of learned something new that I thought I always already knew about! Bedding in pads+rotors correctly is so important and yet so hard to do right?
ZD, This is the same theory as why do wide tires have better grip on asphalt, when technically only the compound should matter?
Its because mu, the coefficient of friction is dependent at a microscopic level on contact area.
The reason why for most purposes mu doesnt change is because of the way surfaces deform. Nothing is ever totally touching so if you put weight on it, The tips elastically deform. THIS deformation is the actual area of contact - which is why mu*normal force doesnt change.
Wide area of seeming "contact" but only a small area is actually contacting.
If we're talking about a really soft material (rubber) OR a strong clamping force (brakes) the contact area does start mattering...if the normal force is strong enough to plastically deform the entire surface area (or most of it) then increasing the surface area does actually increase friction.
Not sure if I'm being perfectly clear, but the rubber tire analogy makes sense, right?
[QUOTE]The reason why for most purposes mu doesnt change is because of the way surfaces deform.
1 Post
I thought it's "Bed-in"
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
Originally Posted by BrakeExpert,Feb 15 2010, 04:55 PM
Sorry, I figured with the obsessive quality of S2000 owners on here, a proper bed in article might help some.
Originally Posted by EngineerX,Mar 8 2010, 01:25 PM
Unnecessary nit-picking. You has it.
