Sponsored by: Sake Bomb
Brembo GT Big Breake Kit - pleas help
Old 10-11-2012, 01:17 PM
bj84's Avatar
Default Brembo GT Big Breake Kit - pleas help
Hello everyone
I'd like to buy Brembo GT 4 Piston Big Brake Kit an example http://item.mobileweb.ebay.com/viewi...d=330620462060
It would be on a 2006 AP1 (europian version) on 18 Work VS-XX, 8 with 50 offset. Would this kit fit?
Thank you all in advance for your help.
Old 10-11-2012, 08:02 PM
bj84's Avatar
Up
Old 10-12-2012, 07:41 AM
bj84's Avatar
Anyone?
Old 10-13-2012, 06:29 AM
Croc's Avatar
expect need for spacers of 15mm at least.
probably more of 17-20mm range.
i've measured templates of quite a few BBK's and this what all of them reuqired.
Spoon caliper didn't fit either.
my wheel have same clearence as yours. and it's already 5mm better than OEM wheel.
i eventually got this kit:
http://shop.3rauto.com/3R-Configured...da-S2K-100.htm
https://www.s2ki.com/s2000/topic/940.../page__st__300
fitted without spacers under my RE30.
Old 10-13-2012, 10:01 AM
bj84's Avatar
Thanks for advise. But on s2ki.com I saw posts with 17x8 25 offset with Spoon BBK. The member had 10mm spacer. Propably noone would tell me is this kit fit before I try on my on...
Old 10-13-2012, 01:12 PM
Croc's Avatar
i would say if there is no fitment template than don't buy!!!
that 17x8 et25 has 25mm MORE clearance over your 18x8 et50. this could even lcear a lot BBKs!!!
i wonder how hard they had to abuse the fenders to make those wheels to fit
you can try TAROX - i've heard they state that their BBK fits inside OEM 17" wheels.
for me it's hard to beleive - but maybe it's true...
Old 10-13-2012, 01:26 PM
bj84's Avatar
Yes but I can buy brand new set less then 1000$. I would say if I do the 10 or 15 mm spacer my offse 50-15 = 35
Yes ?
Old 10-13-2012, 01:43 PM
Croc's Avatar
this is a good deal.
but you will need a big spacer.
Old 10-13-2012, 01:45 PM
bj84's Avatar
I hope 10mm maximum
Old 10-14-2012, 07:00 AM
Croc's Avatar
base on my tests i suspect it will be more than 15mm
Quick Reply: Brembo GT Big Breake Kit - pleas help
