Buddy Club front RCA reviews?
Anyone have any experience with buddy club front RCA/camber adjusters?
I had awful luck with the build quality on Buddy Club seat rails. So I'm slightly apprehensive.
Anyone been using them fot a while? Any issues? Are you happy, or would you have gone with a different option?
over 20 track days, on mine.
no rips in the boot, but I can see minor rubber deterioration in the boot.
thanks for the replies. The boot being junk is predictible...and I think I would likely put an OEM boot on there if it fit.
I was more worried about the ball joint itself, as well as the housing.
Good to know y'all have had luck with them!
I think the OE Honda boots are made from silicone (??) They're fairly indestructible.
More importantly, they fit well.
IDK. I'm debating a RCA setup. But I certainly shouldn't spend more money on the car for a while.
Been thinking this also,
if are not an offset joint,then just use longer bolts.
If they are offset , geo may not be obtainable with oem.
No, offset wouldn't work, but those that just want to correct rc I dont see why a simple shim/spacer couldn't be used. Someone surely makes one, no?
I have been pondering TF out of why nobody makes a simple plate for a front RCA for a longass time.
I was interested in the Buddy Club ball joint for the offsetting function to widen the front track.
