Sponsored by: Sake Bomb
Caliper weights
Old Aug 23, 2012 | 11:27 PM
MB's Avatar
MB
Member
Default Caliper weights
Just wondering if there's a list of all the aftermarket caliper weights somewhere?
I'm trying to reduce some weight on my race car and info is hard to find!
Ones i'm interested in are:
OEM - 4.7kg each
AP CP6637
Spoon - 2.6kg each
Stoptech Trophy 4 pot - 3.7kg each (incl all brackets / bolts)
Stoptech ST40
Wilwood Dynalite 4 pot - 1.46kg each (no hardware)
Wilwood FNSL6R 6 pot - 2.2kg each (no hardware)
Tarox 6 pot 320mm kit B32-6 - 2.2kg each (no hardware)
Tarox 8 pot 330mm kit B33-10 - 2.95kg each (no hardware)
Stoptech Trophy here: https://www.s2ki.com/s2000/topic/834...bbk-installed/
Tarox tech info: http://en.tarox.com/products/racing-brake-calipers.html
Old Aug 23, 2012 | 11:42 PM
macr88's Avatar
I have some Stoptech ST40's I can weigh, I'll try this weekend.
Old Aug 24, 2012 | 01:19 AM
MB's Avatar
MB
Member
Excellent thanks
Old Aug 25, 2012 | 10:53 AM
Croc's Avatar
Dynalite forged 4 pistons - 3 lb 3.5oz = 1.46 kg (no hardware)
Old Aug 27, 2012 | 01:46 AM
Turtle's Avatar
The AP CP6637 with S2000 brackets weigh 5.5kg for a pair. The discs with bells are 12.1kg, again for a pair.
I wouldn't necessarily use that AP kit for a race car. The use of 26mm thick discs helps the wheel fitment but makes for expensive discs for example.
The big benefit from changing the front brakes isn't so much weight, but control. Having a good, rigid, opposed piston caliper gives much better modulation control. The heat management helps as well. It's never just a case of fade, you always want to stay in a consistent area of the mu curve so that you have the feel to brake how you want.
-Brian.
Old Aug 30, 2012 | 08:40 AM
MB's Avatar
MB
Member
Yep agree, thanks Brian
I'm actually quite happy / impressed with the OEM calipers and Dixcel race setup, in that they never fade, never crack discs, and lock my A048s up at will.
Really I'm looking to save weight and maintain reliability / performance, soI thought I'd get a full listing of weights to begin with.
Actually like the look of the Wilwood forged dynalite with 32mm discs:
https://www.s2ki.com/s2000/topic/940...gal-brake-kit/
Old Aug 31, 2012 | 12:13 PM
Urge's Avatar
Sponsor
Mine weigh 2.2 kgs and they are proven to take abuse on 500HP, 2800lbs cars. Its one thing to loose weight, but can they take a beating. We also have a review on a boosted S2K, no fade!! Reduce rotor weight too.
Total weight savings is 15lbs + unsprung!!
Cheap replacement 2 piece rotors and 20mm pads that last much longer than typical thin S2K pads.
__________________
Old Sep 2, 2012 | 06:07 AM
MB's Avatar
MB
Member
Very nice
Old Sep 16, 2012 | 01:08 AM
Croc's Avatar
got my Wilwwod dynalite's today.
the scale shows 1.4 kg.
bracket 0.1 kg.
rest of the hardware (bolts, washers, brkae line adapters) are 0.2 kg each side.
Old Sep 22, 2012 | 01:23 AM
Croc's Avatar
it's not only about the caliper - but also brake disc:
nemesisryder0627
Apr 26, 2022 09:56 PM
thielepr
Mar 10, 2018 08:08 PM
TerminatioN
Jul 7, 2012 04:53 PM
S2S
91
Jul 12, 2010 01:09 PM
AusS2000
Apr 13, 2007 05:01 AM
