Sponsored by: Sake Bomb
can i get your guy's input?
Old Sep 23, 2010 | 07:47 AM
jimnasty23's Avatar
Default can i get your guy's input?
So once i get after my car is done being booted, which, keep your fingers crossed, will be within the next few weeks. But after that my next goal is to get my car lowered, to be honest, its not a race car, i dont plan on ever bringing it to a track and racing period. So i really want to save the 2-3g by not buying coilovers.
So that leaves springs, besides just getting the springs what else to i need to do this right? I really am worried about vibrating and bouncy bouncy rides, and i dont want that. So what should i do? Thanks guys
Jim
Old Sep 23, 2010 | 08:44 AM
clarkster009's Avatar
Eh you can get a decent set of coilovers for a lot less than $2-3gs. I heard springs don't provide any real increased performance (except maybe a slightly lowered center of gravity). I am in your same boat, and am looking to spend really no more than $1500 max. A few companies make "street" coilovers that are supposed to be a little bit more comfortable.
http://www.enjukuracing.com/megan-racing-s...09-p-10488.html Megan EZ Street
http://www.vividracing.com/catalog/hr-stre...-00-p-1614.html H&R Street
http://www.maperformance.com/tein-comfort-...sh64-k1ss3.html Tein Comfort Sport
I may just go with Bilstein PSS (non adjustable) because I could get them for around $800. Hopefully they aren't too firm.
Old Sep 23, 2010 | 10:27 AM
robinson's Avatar
"Lowering Springs" will not provide any real improvement in performance. You'd better believe that stiffer springs do, though, as they limit the overall roll and therfore limit camber change, alowing you to run less static camber. Stiffer springs also limit weight transfer. You may have a bouncy ride because the springs will probably be softer than stock and the stock shocks may not have the force necessary to controll them. As spring stiffness goes up, the required rebound force goes up, but compression forces goes down. As a result most of the lowering springs are softer than stock, and therefore require more compression than the stock shocks have, and require less rebound than the stock shocks have. So either way, lowering springs are not great for the performance of your car.
Old Sep 25, 2010 | 07:05 AM
jimnasty23's Avatar
like i said in my post, im not really looking for track performance suspension, so to be honest, all the other stuff doesnt matter because i never go around a corner at 50-100 and if anything im in a straight line for most of my trips. But i do completly under stand where your coming from.
Old Sep 25, 2010 | 07:06 AM
jimnasty23's Avatar
thanks for the links, the megan racing ones are like what im looking for.
Old Sep 25, 2010 | 03:08 PM
ucb888's Avatar
Where can you get the Bilstein for $800? I'm in the same boat...would love coilovers but need to stick below $1000.
Old Sep 27, 2010 | 05:37 AM
MattZ28's Avatar
Autopartswarehouse.com - use coupon code SAVEMORE and they will come to $792 shipped.
Old Sep 27, 2010 | 07:59 AM
jimnasty23's Avatar
Do the bilsteins still lower the car even though they are non adjustable?
Old Sep 27, 2010 | 08:28 AM
MattZ28's Avatar
The damping rates are not adjustable on the PSS. Height is adjustable.
kw_21
Jun 12, 2014 03:04 AM
mfresh422
Sep 15, 2012 03:54 AM
dipset chink
Sep 12, 2010 10:29 PM
iheartS2K
May 28, 2008 06:40 PM
MAD828
Jul 19, 2007 07:21 AM
