Sponsored by: Sake Bomb
Clunk noise
Old Sep 14, 2013 | 04:49 PM
joshf47's Avatar
Default Clunk noise
Hey guys,
Im getting a clunk noise when i hit a bump from my front right.
i took the wheel off and everything felt solid nothing was loose
Not really too sure what it is, im going to take it to honda on friday
but like to see what you guys think it could be first
thanks
ps my car is lowered on BC n+
Old Sep 14, 2013 | 05:51 PM
slowd16's Avatar
Top nut on the shocks tight? Do you have an aftermarket swaybar?
If you take it to honda I bet $100 they say its because the car is lowered and don't bother actually looking at it.
Old Sep 14, 2013 | 06:23 PM
p0staboy's Avatar
I have a clunk noise also, mine is coming from the right rear tire. I have BC n+ also.
Old Sep 14, 2013 | 07:40 PM
joshf47's Avatar
yeah all the nuts are tight, OEM swaybars
Old Sep 15, 2013 | 12:40 AM
boyguan's Avatar
Disconnect sway bar link and see I'd noise goes away
Could be upper shock mount
Old Sep 15, 2013 | 06:57 AM
joshf47's Avatar
How can I drive it to see if it makes the noise with my link disconnected
Old Oct 2, 2013 | 07:41 PM
tkeyyy's Avatar
had a clunk in the drivers rear due to the spring sitting incorrectly, but the spring eventually lost the battle and settled.
other times when i had clunks were due to either subframe being loose or LCA.
does the clunking occur when you're braking or hitting constant road bumps?
Old Oct 2, 2013 | 07:46 PM
rota92's Avatar
It will drive as usual, except without the help from the sway bar. Just don't tool on it as the handling characteristics will be different.
Old Oct 8, 2013 | 08:03 PM
boyguan's Avatar
We are talking metal clunk or regular clunk?
My buddy club top nut on the pillow ball worked loose. It's the one on the adjuster not the one that holds the shock to the car
Otherwise check the sway bar. Disconnect one side and tie it somewhere so it won't hit anything.
Old Oct 9, 2013 | 02:00 PM
joshf47's Avatar
it 100% was a loose nut on the adjuster i figured it out a couple days ago, good looking out tho
