Sponsored by: Sake Bomb
CR Steering Rack Stiffeners on an Ap1 Any Good ?
Old May 22, 2012 | 04:28 PM
zeroptzero's Avatar
Default CR Steering Rack Stiffeners on an Ap1 Any Good ?
I've got my front end opened up while doing an engine swap, which has me thinking about the CR steering rack stiffeners while I wait for my engine to be built.
I found one thread on the stiffeners but I never found any real opinions on whether the upgrade is of any value on a non-CR S2k. It almost seems like they are designed to transmit more feel through the steering rack, is there any real benefit to putting these on a Non-CR model ?, thanks or any opinions.
Old May 22, 2012 | 05:06 PM
macr88's Avatar
Instead of two bolts carrying the load you'll have the load distributed to roughly 4 bolts and I say roughly because there's no attachment point for the rear brace to te subframe like there is on the CR
Old May 22, 2012 | 05:13 PM
zeroptzero's Avatar
thanks for the quick reply, yeah I was wondering if the subframe even had the 2 mounting holes for the rear stiffener. I guess I could do the front stiffener on its own, but I'm starting to think this probably isn't a worthwhile mod. ?
Old May 22, 2012 | 05:50 PM
macr88's Avatar
I wouldn't call it a mod but it is nice knowing that it shouldn't flex as much.
Old May 22, 2012 | 06:18 PM
zeroptzero's Avatar
Is there any benefit in just doing the front stiffener on it's own ? cost is not a consideration. Thanks for the replies.
Old May 23, 2012 | 05:25 PM
Carbon Blue's Avatar
id be interested to know as well...
Old May 23, 2012 | 05:48 PM
petawabit's Avatar
they're cheap and easy to install? i would comment, but i installed the cr stiffeners along with an ap1 rack and the rigid bushings that replace the oem rubber so it's hard to say. all the mods above made a small, but noticable difference. while you're at it, might as well upgrade the bushings to l-con or spoon steering rack bushings since that would be the next place that the cr stiffeners would cause to flex.
Old May 24, 2012 | 03:34 PM
ungucpho's Avatar
I installed the cr stiffening racks. it's tough to say they did anything besides me saying I have them installed
Old May 24, 2012 | 03:50 PM
zeroptzero's Avatar
Thanks for the replies petawabit and ungucpho, it's great having some real world info like that.
INTJ
Sep 9, 2014 07:08 AM
s2kdriver80
Jul 7, 2011 07:35 PM
iLuveketchup
Jun 25, 2011 01:31 PM
