custom rotors
Hi.
Does anyone know the offset of project Mu SCR PRO rotors hats?
I know the rotor is 300 mm diamenter and 25mm wide like oem.
So if I want to use a 32mm wide rotor does it means the offset of the rotor must be 7mm less than oem to keep it in the same centerline of oem?
How far can we go on offset with 32mm wide rotor on front an rear before any clearances issues ?
This is for a custom brake system, will be 356mm diameter front and 330 rear.
Tanks
Tanks
hum . if you bolt on a 7mm wider rotor on the same hat it will go inside . in this case to maintain the same centerline i would need a hat with 3.5mm less offset. to maintain the same clearance of the kuckle i would need 7mm less offset.
The whole point of the question is to know how much can i go on offset with a 356mm 32 mm wide rotor before having clearance issues. anyone had experience with this ? i would need to make custom hats or see if i can get off the self ones .
How much offset does the sakebomb 325mm 32mm wide rotors hat have for example? anyone?
Krazykoreankid
Cars for Sale
Jun 26, 2019 08:10 AM
inderjeetgill1
Oct 28, 2018 03:36 PM
jungle
Jul 12, 2018 02:55 PM
