View Poll Results: What sway bars are you running for BS autox?
Voters: 27. You may not vote on this poll
Difference between Saner and Eibach Swaybar?
Front swaybars are hard to come by for these cars, well if you want a good one for a good stock class autocross setup, which is what I'm looking for. I've read the threads, researched, etc. and it seems that if you want one of the saner, gendron, or comptech bars then you better cruise ebay, craigslist, or an endless number of S2000 or Autocross forums to find someone who's selling one. That being said, I have read that the Saner is a 1.25" Solid bar and the Eibach front bar is also a 1.25" Solid bar. So why is there no interest in the Eibach bar? I understand that a lot of people find that it isn't enough front bar for the S2000 (particularly AP1's, which is what I'm getting), so perhaps this is the main reason? Or maybe most of the guys autocrossing these at the national level have purchased cars from others that did the same thing before them, etc. so the car came with the swaybar.
Thanks for your insight. Any input is appreciated, but I'm not particularly in the market for the swaybar right now, although if one comes up I would be inclined to make an offer.
Most national level auto-xers use a different bar, like the Gendron or ARE bars, because they are lighter, have a larger adjustment range, higher stiffness potential, better endlink hardware, and better chassis mounts. Plus, the higher priced bars retain their resale value well.
I have never seen or used the Eibach, so I cannot comment on the construction. But, I suspect it would have similar negative characteristics to the Saner.
If you have some fab skills and the right tools, you can also make your own front anti-roll bar from readily available components from Speedway Engineering. Here's a bar I made for use on my STR build:
Hope that helps.
I'm looking at either a 2003 or a 2004. I know there are some serious differences in the two cars, engine size, as well as other things. I'm leaning more towards the 2003, but it depends on the price, mileage, etc. of the particular car. I'm indifferent if it comes down to just the year.
I was mulling it over in my head, making my own bar that is, but I wasn't sure where to start. I looked for 1-3/8" solid steel tubing, but I was not able to find it from a readily available supplier. Speedway engineering looks pretty sweet! I'll probably go the homemade route for that matter, seems pretty straight forward. I'm assuming you used the 30 degree bend steel swaybar ends bars?
Thanks for the help, this was much appreciated.
-Austin
-Austin
I see, so your end bars aren't shaved, but bent a little more so they are a little more than 30 degrees, or did you also add some bending in the other direction (left-right direction while attached to the vehicle) to miss the brake line?
Sent these details to Austin, but I figured I'd share with the rest of the forum. I thought about manufacturing these and selling them...but I just don't have the time to invest in making multiple sets. So, here are some of the details...
I'm using the 1.25"OD .25" thick bar. Typically 1.375"OD is the largest bar anyone uses in B-stock trim. Depending on the bar arm design, you can get some fairly high rates from the 1.25"OD bars. They also offer a solid version. I was going for weight reduction over my Saner bar, which is why I opted for the hollow version.
The Gendron FSBs and my bar both use the 36" bar length. It seems to be just about perfect, even in STR trim. At full lock, the tires just barely clear the ends of the bar.
I did make adapter plates for the bearing mount. Here is the DWG and some images:
Drawing:
Test pieces:
Bearing mount (McMaster P/N 5912K11) in place:
Socket clearance:
Final versions for another auto-xer:
Mounted with shaft clamps (McMaster P/N 6157K21) in place:
The bars were plasma cut to size and I did add some lateral curvature to them. I bent them out ~2" at the ends, with the splined portion in the vise. The holes were drilled prior to bending the arms.
Standard arm vs. plasma cut:
Arm-to-brake line clearance before bending:
Clearance after bending:
Building the bar required a decent amount of time and effort, but I'm really please with the result. The design also weighs ~2 pounds less than the comparable Gendron design that uses the same bar section, according to weights from other auto-xers.
Drawing:
Test pieces:
Socket clearance:
