Sponsored by: Sake Bomb
DIY: Brake Bleed (Gravity Method)
Old Mar 10, 2014 | 06:21 PM
  #51
marks_lude's Avatar
Originally Posted by HvRRZ
Bleed Order: Right Front(Passenger Front), Left Front(Driver Front), Left Rear(Passenger Rear), Right Rear(Driver Rear)
Is there a typo?
You state pass front as "right" and then pass rear as "left"
Old Sep 28, 2014 | 05:01 PM
  #52
HornedFrog's Avatar
Did this today. Perfect pedal. Pumped brakes on each corner but it did take a while, about 2 hours total.
Old Oct 1, 2014 | 07:03 AM
  #53
Car Analogy's Avatar
Originally Posted by Mattyg2
Are you guys sucking every last bit of fluid from the reservoir or just down to the LOW line? Wouldn't sucking out all the fluid let air in? Or am I missing something here.
Get out as much as you can. Then when you wipe it out with paper towel you will get the rest. No, you won't add any air, so long as you don't have any bleeders open yet or pump the pedal while the resevoir is empty.
For those having to resort to pumping, is your MC lid in place? That would impede the flow. Leave the cover off. BUT, if you do end up having to pump, put the cover back on. Some fluid can jump when you are pumping and spill out of the resevoir.
Gravity = cover off
Pump = cover on
I wait to do this procedure until its time to change my trans and/or diff fluid. Car is already level on jack stands. So I just remove wheels, set it up to bleed a corner, then go about process of trans/diff maintenance, making sure to stop and refill MC resevoir often and check if its time to move to the next corner. This way I fill the waiting time doing other maintenance activity.
Old Nov 11, 2014 | 09:41 AM
  #54
Acethriller's Avatar
I'm curious about how much fluid should be bled out of each corner?
Wondering since the new fluid I'm putting in is the same color as the fluid in the car now, would be kinda hard to tell when the new fluid starts running through.
Old Nov 25, 2014 | 02:56 PM
  #55
S2KHANG's Avatar
Originally Posted by Acethriller
I'm curious about how much fluid should be bled out of each corner? Wondering since the new fluid I'm putting in is the same color as the fluid in the car now, would be kinda hard to tell when the new fluid starts running through.
Your old fluid currently in the vehicle should be darker IMO, unless you flush your brake fluids every 1000 miles or use black brake fluid lol.
Old Nov 28, 2014 | 04:27 PM
  #56
steven88's Avatar
You should be able to see it easily through the tube. And I would say about 100ml of fluid will drip out until it turns completely clear, or amber or whatever color fluid you're using. It might be less than 100ml, but that's just my estimate. I was using an arrowhead 500ml bottle as my catch can. And I only filled her up 3/4th of the way after flushing each caliper with gravity.
Old Nov 29, 2014 | 10:19 PM
  #57
Alright, thanks for the info guys! Will do this once the car's out of storage next spring.
Old Mar 15, 2015 | 05:57 PM
  #58
Yaupon's Avatar
Older thread, but OP thanks for the great write up.
Old Apr 4, 2015 | 10:45 AM
  #59
Mike S.'s Avatar
Originally Posted by TotalBalance
Great write-up!
I noticed a mistake in the write-up where you state the bleeding sequences. It is suppose to be 1)pass front 2) drive front 3) drive rear(LEFT rear) and 4) pass rear (RIGHT rear), right? But the sequence you wrote now for rear is mixed up with pass being left and drive being right
Correct. Latest Billman250 brake bleed says:
4- By trial, I've found the best sequence is RF, LF, LR, RR. Start with the right front bleeder. Attach a 12" clear hose to the bleeder screw (10mm), running DOWN to a container below the level of the Brake caliper and let it gravity bleed till it turns blue (no need to sumbmerge the line in Brake fluid)
The original poster HzRRZ's detailed writeup and pictures do actually follow the Billman250 sequence though what he states right at the beginning (see below) is different.
So the below 06 Dec 2012 quote is INCORRECT......just use Billman250 sequence RF, LF, LR, RR or follow original poster HzRRZ's detailed writeup and pictures.
Thanks HvRRZ and Billman250 and TotalBalance!
Bleed Order: Passenger Front, Driver Front, Passenger Rear, Driver Rear (Credit goes to Billman250 for the bleed order. I've been using this order for some time since he suggested it years back. Great contributor to the s2k community, and very knowledgeable mechanic with a long history of working on our cars.)
Old Apr 4, 2015 | 11:05 AM
  #60
JulieU's Avatar
Administrator
Fixed.
