Eibach Pro Kit
Eibach Pro Kit
Hi guys, new to this forum so hi!
A week ago i installed the Eibach Pro Kit to my S.. Install went fine no problems but i have noticed that the offside is slightly lower than the near side (Right hand drive).
Has anyone had the same issue before?!
offside like soccer off side? LOL
well couple things to check
1)spring seat: check to see if the lower portion of the coil is seating against the "seat" on the damper.
2)Preload: probably no way to check this unless you did the installation, if you don't preload the suspension before you tighten the fastener, some corner might sit a tad lower than other.
3)break in time/mile: did you give it enough time and mile for all four corner to settle?
