Sponsored by: Sake Bomb
Failed caliper bleed caused VSA ! Light to come on.
Old Oct 17, 2025 | 06:06 PM
rerland's Avatar
Unhappy Failed caliper bleed caused VSA ! Light to come on.
After replacing one of my front calipers on my 07, I misjudged the fluid level while bleeding and I ran the brake master cylinder dry. Got all the air out but now the VSA ! light is on. My Bluedriver code reader doesnt seem to work for this sort of thing. Been reading through the forums and not seeing on this subject. Wondering what to do now.
Old Oct 17, 2025 | 09:16 PM
Patrick_p3's Avatar
When the master cylinder ran dry, air entered not just the brake lines but also the ABS hydraulic unit. Regular brake bleeding won't remove air from the modulator - it requires the ABS pump to cycle to purge air from those internal valves.
2 options:
A. Take it to a dealer: The proper fix requires a scan tool that can activate the ABS pump and cycle the solenoids in the modulator while bleeding. Your BlueDriver can't do this.
B. Try the "hard brake/ABS activation" method. Find a safe, empty gravel or loose surface area. Drive at low speed (15-20 mph) and brake hard enough to activate ABS. This cycles the modulator valves and may purge the air. Return home and rebleed the brakes normally. Sometimes after getting all the air out, the light stays on just because the code is stored. Try disconnecting the battery for 10-15 minutes to reset the system. If air is truly gone, the light may stay off.
The dealer route is the most reliable solution. The ABS activation method works for some people but isn't guaranteed
Old Oct 22, 2025 | 09:12 PM
Jub's Avatar
Jub
Did you take off or mess with a wheel speed sensor at all?
I learned this year that wheel speed sensors are incredibly sensitive and ABS will freak out badly if they're off at all.
Old Dec 11, 2025 | 12:21 PM
rerland's Avatar
Default Failed caliper bleed VSA light on
2 options:
thanks Patrick! Ill try the gravel road method first and see what happens. If that fails, I'll try my local S2000 shop next. Dealer is convenient but not a fan.
thanks again for your reply!
Old Dec 11, 2025 | 12:31 PM
rerland's Avatar
no, I dont think I touched the speed sensor. Maybe I did... I feel its because i sucked air into the system. Pumped it one too many times
Old Dec 11, 2025 | 02:33 PM
engifineer's Avatar
How does the brake pedal feel? Does it feel soft like there is air in the lines? Air in the ABS system will cause a soft pedal as well. I have done the hard brake method to get air out of an ABS module I replaced on mine but it was definitely noticeable in the pedal. I did it on pavement, but gravel will make ABS engage easier.
froppybirds
Jun 23, 2023 07:18 PM
nichigo
May 8, 2019 03:55 PM
Rez311
Jul 11, 2016 09:46 AM
bewareofthepoop
Jul 30, 2013 09:47 PM
Random1
Sep 3, 2005 07:51 AM
