Sponsored by: Sake Bomb
Front Alignment with 1" Springs?
Old Jul 5, 2013 | 02:07 PM
Hakkaboy's Avatar
Default Front Alignment with 1" Springs?
I just had my alignment done and noticed that my front camber and caster is "out of spec".
LF: -1.4 camber 6.9 caster -0.01 toe
RF: -1.5 camber 6.9 caster 0.00 toe
Total toe -0.01
LR: -1.5 camber, 0.14 toe
RR: -1.5 camber, 0.15 toe
Total toe 0.29
The fronts pretty much matches my "before" settings from 4 years ago when I first got the springs installed + alignment.
Tire wear in the front has some very minor camber wear and i just flipped the tires.
Not bad for 4 years of driving (approx 25K miles) and the tires were used when i bought them, but I guess my question is that the alignment shop told me that my he couldn't get the front camber any lower than -1.5/-1.4.
Is this normal for our cars with only 1" drop? Tein S-tech's with stock shocks.
Thanks.
Old Jul 6, 2013 | 01:05 AM
ZDan's Avatar
Your alignment is totally fine. I run that much front camber and more in back for my stock DD ap1, never felt the need to flip tires. No worries, proceed.
Old Jul 8, 2013 | 07:58 AM
Hakkaboy's Avatar
great thanks. yeah, i drove w/ a -1.5 in the front for 4 years so it wasn't too bad. Was just wondering if it's possible to dial in down any further but i guess it's not possible stock. cheers.
Old Jul 8, 2013 | 09:08 AM
s2000Junky's Avatar
There is probably room left, but you would need to give up some caster to do so, assuming he did in fact max out the camber adjuster. I wouldn’t bother though since I agree that the total alignment is good as is.
Boost76
Sep 14, 2009 08:31 AM
kylemonster85
Apr 29, 2008 12:30 PM
S~Factor
Jun 12, 2007 04:23 PM
s2addict
Oct 8, 2005 09:36 PM
LubedKoala
Sep 17, 2005 05:07 PM
