Sponsored by: Sake Bomb
front coilover preload
Old May 17, 2010 | 06:09 PM
Nick.'s Avatar
Default front coilover preload
hey all.
i have recently been having an issue with my front wheel/tire rubbing the front fenders and pulling out the fender lip.
the wheels are 17x7.5 +45 with a 215/45/17. this ONLY happened when turning into my driveway with the wheel cut all the way right.. the front of my car has atleast a 1 finger gap so its not slammed.
the front is pretty bouncy and im pretty sure it's because the preload because once i re did the rear coilover preload it became very stiff.
so my question is.
WOULD INCORRECT FRONT COILOVER PRELOAD CAUSE MORE SUSPENSION TRAVEL, IN TURN CAUSE THE TIRE TO GRAB THE FENDER WHEN COMPRESSED WITH THE WHEEL TURNED?
sorry for the novel, i'm getting new fenders and dont want to mess em up.
-Nick.
Old May 18, 2010 | 01:52 PM
s2k dre's Avatar
The reason its grabbing the inner fender is cause u dont have enough camber. Set the spring preload at zero and adjust the stiffness on the coilover.
Old May 18, 2010 | 03:27 PM
eddiealiano's Avatar
i had the same accident... mine its drop on koni yellows and tein s techs,,,, im getting ground control coilovers tho, so i can raise the car a lil bite.
Old May 18, 2010 | 06:54 PM
Nick.'s Avatar
so should i camber the wheels in too?
i was going to have the inner lip cut out by s-factor.
Old May 20, 2010 | 12:19 PM
Nick.'s Avatar
im going to bring it in to set the front camber, what would you recommend? -1.5?
Old May 20, 2010 | 03:23 PM
Rdizzle's Avatar
The place that did my alignment said the front camber on our cars push the bottom of the wheel out instead of bringing the top in. If that's the case, then camber won't help.
You can adjust the dampening on your coilover to be more stiff. You'll probably have more luck there than pre-loading your spring more. The permanent fix is to roll your fenders or cut out the part where the liner mounts up (or do both).
Old May 20, 2010 | 06:42 PM
Nick.'s Avatar
they are full stiff, but i think since the spring isn't installed right they arent as stiff as they could be.
Old May 20, 2010 | 07:31 PM
S2K Sideways's Avatar
i had a similar issue... check out your springs because if they are too compressed your shocks will basically not be working...therefor your stiffness on your coilovers that you adjust from the top is pointless... worked for me..good luck
Old May 20, 2010 | 08:01 PM
Nick.'s Avatar
thats my exact issue actually, you were rubbing/pulling out the fender lip on turns?
Old May 21, 2010 | 04:02 AM
importkid's Avatar
A wheel is flat, hard, and round. What ever you do to one side gets the opposite effect on the other. Running negative camber will make the tire lean inwards up top and out on the bottom. you are pushing on the lower control arm cam to move the hub in a slope like \.
OP, only cut the fender lining where it is rubbing. The linig holds regidity for the front bumper corners.
