Sponsored by: Sake Bomb
Function Form Type 2
Old Feb 20, 2014 | 06:31 AM
Lowlifexs2k's Avatar
Default Function Form Type 2
whats your opinion on these? how is the ride quality?
Old Feb 20, 2014 | 07:13 AM
lopez14's Avatar
Judging by your name you want to be really low. I'm running the type 2s and I like them, they have 32 dampness levels so you can adjust them to your liking. I'm pretty low so I have them at the stiffest setting so I don't bottom out and even then my ride quality is really good. At least in my opinion.
Old Feb 20, 2014 | 09:42 AM
thats good to know thanks im still deciding between these or the ksport kontrol pros. my cars at a decent height right now lol
Old Feb 20, 2014 | 03:39 PM
notorious9i6's Avatar
These are great budget coilovers. They daily well and have a wide range of dampening to suit your needs. I DD with them and love the way they perform. 2+ years and they still ride well
Old Feb 20, 2014 | 03:44 PM
Thanks for your Input
Old Feb 20, 2014 | 06:17 PM
S2K Al's Avatar
Hi, just nit-picking here but I think folks will appreciate the slight correction and knowledge for the future. The correct term is damping, and not dampening, dampness or dampering (as I've seen in the past).
Along the same lines, the most "ways" in which a damper can be adjusted is 4. The number of levels will typically refer to the degree to which a particular "way" of damping adjustments can be made (low speed rebound, high speed rebound, low speed compression, high speed compression).
Old Feb 24, 2014 | 07:06 PM
2 Ravens's Avatar
Any of you guys have pics of your F&F setups?
Old Feb 25, 2014 | 03:22 PM
lopez14's Avatar
Set ups as in how the car sits or the actual suspension setup it self?
Old Feb 25, 2014 | 04:22 PM
2 Ravens's Avatar
How the car sits, I should have stated that lol
Old Feb 25, 2014 | 06:26 PM
lopez14's Avatar
Crappy iPhone pic but heres one, there ls way more to go. You could lay frame if you wanted to but that's low enough for me, and of course you could go higher as well
