Sponsored by: Sake Bomb
Help on installing CNC staging brake.
Old Jan 18, 2016 | 11:33 AM
Prokaw875's Avatar
Default Help on installing CNC staging brake.
***Moderators please more to forced induction thread as it may have better luck in there since it is primarily a drag racing thing.
So I just picked up a CNC Hydro staging brake for my drag/street s2000 build. I am a little unsure of how to plumb everything but think I have it figured out now. Just want to know what other peoples opinions are on it and if it makes sense that it will properly work. A few key points are listed below and the system design is above.
-CNC Hydro Staging brake with res. and single port.
-Intend on locking only the front brakes when doing burn outs to stay in place and help stage. (So pulling the staging brake must not effect the rear wheels)
-Factory ABS has been deleted and system is built off of an OEM master cylinder and a DA/DC integra "40/40" proportioning valve
RED=New lines for foot brake. 2 from master to p-valve. 4 out of the p-valve to each wheel
GREEN=Lines to operate front brakes independently from foot brake with out effecting the other system.
I believe by just adding 2 check valves on each front line after the p-valve but before the staging brake Tee`s into it I shouldn't have any issues.
[attachment=89987:stagingbrakediagram.png]
[attachment=89985:cnc_stage_brake1.jpg]
Attached Thumbnails Help on installing CNC staging brake.-cnc_stage_brake1.jpg   Help on installing CNC staging brake.-stagingbrakediagram.png
Old Jan 19, 2016 | 08:35 AM
Prokaw875's Avatar
Anyone?
Old Jan 27, 2016 | 07:12 AM
Prokaw875's Avatar
Damn... No one?
Iambob911
Sep 1, 2015 09:10 PM
trackrabbit21
Aug 11, 2015 11:14 AM
Chablonski
Mar 17, 2010 10:22 AM
plokivos
Feb 7, 2008 05:21 AM
