Sponsored by: Sake Bomb
Help: Lowering Front End
Old Apr 24, 2011 | 11:02 AM
raneyboo's Avatar
Default Help: Lowering Front End
I want to go lower in the fronts but they hit my control arm, any suggestions?
Old Apr 24, 2011 | 12:51 PM
illestrolla's Avatar
Are you talking with the car jacked up? or suspension loaded sitting on the ground? My perches sit pretty much on my Upper CA with no load on the suspension but the angle of the shock changes dramatically when you load it
Old Apr 27, 2011 | 09:37 PM
raneyboo's Avatar
Both, I can't lower it anymore since it hits the control arm so its lowered as much as possible with this constraint. When you look at my coilovers,they have some scrapes and grinding against the control arms.
Old Apr 28, 2011 | 07:18 AM
robinson's Avatar
If it hits the A-arm, then you can't go lower, simple as that.
ceek732
Aug 3, 2017 06:57 PM
jsenclosure
Feb 28, 2017 08:11 AM
deibit
Aug 1, 2011 09:38 PM
s2kpdx01
Aug 9, 2002 09:05 AM
