Sponsored by: Sake Bomb
How to make S2000 HIGHER
Old 06-08-2010, 11:21 AM
KOOLER's Avatar
Default How to make S2000 HIGHER
Hi guys,
what's the right way to make S2000 higher then stock? Say +15 mm in the rear and +10 in the front? I know it may sound stupid but there are no roads here, only directions With my GT-R I've been putting spacers between coilovers and chassis, would the same work for S2000 as well?
Thanks!
Anton
Old 06-08-2010, 02:41 PM
INTJ's Avatar
There is no simple way. A whole new top hat with a longer spacer? The length of the shock is the limiting factor. So a ground control replacement spring with a longer and stiffer coil is the only way I can think to do it cheaply
Old 06-08-2010, 06:40 PM
TheProfessor's Avatar
Fail!
Old 06-09-2010, 06:24 AM
crank's Avatar
get some rouberta cups (spelling?)
Old 06-09-2010, 10:50 AM
KOOLER's Avatar
Google is silent Any ideas where to look?
For now I'll be installing +10 mm spacers over the coilover mount.
Old 06-10-2010, 03:53 AM
00wreckedS's Avatar
Roberuta Cup kit can be found on the Top Secret website.
Old 06-10-2010, 12:32 PM
KOOLER's Avatar
Thank you very much!
Old 06-10-2010, 05:10 PM
Jacks2KiNG's Avatar
oem is already 4x4 status! you want lower not higher
Old 06-10-2010, 08:22 PM
GrandMasterKhan's Avatar
i am sure there are coil cover kits which will allow you to thread up higher than the stock position. Good luck getting an alignment though.
Old 06-11-2010, 02:05 AM
TRD_Celica's Avatar
get a truck?
Quick Reply: How to make S2000 HIGHER
