Sponsored by: Sake Bomb
Installed coils, uneven ride height?
Old May 16, 2014 | 03:14 PM
leoxle's Avatar
Default Installed coils, uneven ride height?
Hey everyone, so I just installed some brand new Fortune Auto 500 coilovers. Everything went pretty smoothly, and I lowered the car back down and it seems that the drivers side front is about 4-5 mm's or so higher than the passenger front. I did make sure to check preload which were even, and I adjusted the coilovers height evenly before installing them. I have not gotten an alignment yet, maybe that would fix it? The difference isn't much at all but it still bothers me. Should it be completely even? One possibility could be that when installing the coilovers, the bottom mount had to be turned slightly to be able to be mounted on the lower control arm, because with the fortune auto's design, the bottom mount is one whole piece and turning it is how you adjust the ride height to my understanding.
I looked this issue up and some other people seem to have had the same thing happen. Since I set the preload and height of the coils off the car evenly, I'm not sure what else to do but get the alignment. Any ideas?
Old May 16, 2014 | 05:08 PM
jst2878's Avatar
Was your ground level? You can adjust that 4mm by two full turns off the two locking nuts. The body will move accordingly
Old May 17, 2014 | 10:50 AM
leoxle's Avatar
Yeah I'm pretty sure it was ground level, did it in my garage. Will recheck on a different surface. And by the two locking nuts, do you mean the spring perch? I thought the only way to adjust ride height was through turning the bottom mount which has to be taken off the car to adjust.
Old May 17, 2014 | 01:35 PM
alphalanos's Avatar
Make sure A and B are locked tight together. loosen C upwards to give some room. Put the wrench on A and turn the whole body until its the height you want. then tighten C again.
Measure the car height from level ground up to the jack points underneath
Old May 17, 2014 | 10:42 PM
leoxle's Avatar
Awesome, thank you. I originally thought that turning A would change the spring preload. Is that not the case? I'm assuming that by locking A and B together, it locks in the preload and by turning A, the entire shock body moves? I read somewhere that it's supposed to work like that.
Old May 18, 2014 | 04:59 AM
iamatlas's Avatar
OP have you driven your car at all since the install? It could well be that the suspension just needs to settle and then you can adjust and get an alignment. If not you'll have to redo both again
Old May 18, 2014 | 06:36 AM
Sebring AP1's Avatar
You're aware most garages are not level, right? It would be incredibly rare to find ground that is actually "perfectly flat"
Old May 18, 2014 | 06:46 PM
leoxle's Avatar
Yeah I have. I will remeasure tomorrow.
Originally Posted by Sebring AP1
Originally Posted by leoxle' timestamp='1400352649' post='23164196
[quote name='jst2878' timestamp='1400288924' post='23163651']
[/quote]
I know, but my house is built on a really flat surface, it's not like some that are on a hill. But yeah of course it'd be hard to get it completely flat. I will measure again somewhere else to double check.
Old May 28, 2014 | 09:42 AM
cheddaboy's Avatar
I have the same issue. I have PSS9's and the rear pass side is a tad higher than the driver side..both coils are maxed out..
Orleansjunky
Sep 19, 2017 03:15 PM
jst2878
Jul 1, 2014 01:27 AM
MR.T
Aug 13, 2013 11:48 AM
jst2878
Oct 23, 2012 11:56 AM
NVD52K
Aug 12, 2008 10:02 PM
