Sponsored by: Sake Bomb
Installing coils, passenger side stuck
Old Oct 17, 2016 | 10:30 PM
wongs2k's Avatar
Default Installing coils, passenger side stuck
Hey guys I'm putting in a set of fortune auto coilovers, got the driver side front and back installed fine but both the passenger side stock suspension is stuck after removing the bottom 17mm bolt.
Both passenger front and back are in full tension against the lower control arm and I can't budge it, did not have this problem with driver side.
Any suggestions ? Do I need a spring compressor
Old Oct 18, 2016 | 05:59 AM
B serious's Avatar
disconnect your swaybar.
B serious's Avatar
also unbolt your upper control arm in the front
Old Oct 18, 2016 | 06:48 AM
RedCelica's Avatar
Ive never had to unbolt my sway. Just make sure the entire car is up in the air. If you dont have 4 jack stands, just do the entire front first. One side being down puts a lot of tension on the sway and torques the suspension to one side.
Old Oct 18, 2016 | 07:10 AM
B serious's Avatar
yes...he likely has one of the FA's bolted to the LCA. It is short. The stock shock is long.
The swaybar is pulling up on the stock shock side and trapping it.
OP could also just unbolt the LCA from the FA side.
Old Oct 18, 2016 | 07:11 AM
B serious's Avatar
Unbolting swaybars makes it easier. If his are "stuck", maybe there's an issue with how much force he can use.
Old Oct 18, 2016 | 11:24 AM
wongs2k's Avatar
That's crazy, if it's the sway why didn't the problem occur on the driver side. I'll try it. If it still doesn't work I'm cutting the damn strut.
Old Oct 18, 2016 | 12:06 PM
B serious's Avatar
I explained why.
Old Oct 18, 2016 | 04:27 PM
wongs2k's Avatar
Understood. Didn't think of that, I guess next time the lesson is to install both sides before bolting in tight.
Old Oct 18, 2016 | 04:46 PM
B serious's Avatar
Cool, bud. Glad you got it figured out.
