Sponsored by: Sake Bomb
knocking noise
Old May 22, 2012 | 11:32 PM
adriandjesus's Avatar
Default knocking noise
hello guys, so i lowered my car on buddy club coilovers bout 2 months ago now and ever since install it had a knocking noise on one of the rear strut/shock when i go over bump or driveway or pretty much when the car is "flexing" and today i finally had time to check it out at first i thought it was just the suspension settling in but i found out that the top hat bolt lost it's groove? is that what its called when you tighten it but it doesn't tighten n just turns? is this the cause of the knocking noise? can I send it in to buddy club to get it fixed? i bought it used =/ *i don't wanna hear anything about buying it used as I'm aware of the risks* I'm just here to find out ways to fix this :]
Old May 23, 2012 | 06:34 AM
RaulChavez's Avatar
Did you preload the suspension/bushings ?
I had the same knocking sound when I re-installed my springs while "flexing" the rear, went away after preloading.
Old May 23, 2012 | 10:12 AM
yep I preloaded the suspension =/ i even got my friend who gets paid doing suspension check out the preload.
Old May 23, 2012 | 10:21 AM
the middle one is what's not tightening...
Old May 23, 2012 | 11:18 AM
s2cho's Avatar
same process http://www.youtube.com/watch?v=f08AQH5wxGU
Old May 24, 2012 | 04:57 PM
Mr White's Avatar
re-torque everything. I had this problem and my rear sway bar was just a few lbs off..
Old May 24, 2012 | 07:11 PM
the thing is that i torque it but it doesn't get any tighter =/
Old May 24, 2012 | 07:27 PM
Carbon Blue's Avatar
you stripped the threads off, that is due to over torque'ing or cross-threading that nut. I dont know how you could fix that besides sending those shocks back into buddy club to have that part replaced, or you could do it yourself.
Old May 25, 2012 | 03:26 AM
S2KIrishman's Avatar
you can always try to grab the top threads with vise grips and try and turn that nut with a wrench...i have to do that sometime whenever im doing shocks or struts that ave been on a car a little too long
boiii4
Jul 10, 2014 08:08 AM
Nick.
Apr 29, 2010 09:25 AM
s2ksks
Oct 1, 2009 08:30 AM
J.nguyen
Oct 16, 2008 01:05 PM
