Sponsored by: Sake Bomb
rear suspension noise
Old Apr 25, 2010 | 06:09 PM
Nick.'s Avatar
Thumbs up rear suspension noise
hey all.
i have the odd rear suspension noise. it began after i installed my coilovers (ARK ST-P). the helper springs are threaded all the way up so i dont think its the spring slapping around, yet it does sound like that.
the noise is REALLY inconsistent, sometimes over bumps and sometimes not. sometimes i hear it just when i jump into the seat.
the noise is also considerably louder/frequent on the passenger side.
maybe i have the spring/collar/helper spring setup wrong?
thanks guys.
-Nick.
ps. i could snap some pics if it will help any..
Old Apr 26, 2010 | 06:16 PM
Nick.'s Avatar
hmm nobody has had a noise from the rear coilovers?
Old Apr 27, 2010 | 11:00 AM
award78's Avatar
I'm having a weird noise from the pass. rear after eibach spring instal and 18" wheels. It almost sounds like somethings loose, but mechanic says nothings loose. Haven't figured it out yet, but will let you know if I do.
Old Apr 27, 2010 | 04:08 PM
Nick.'s Avatar
ya i am the mechanic and nothing on my car is lose either. such a weird noise.
Old Apr 27, 2010 | 04:29 PM
award78's Avatar
Are the springs compressed? Easy to spin?
Old Apr 27, 2010 | 05:04 PM
Nick.'s Avatar
the helper spring is fully compressed up against the upper spring. i can not spin any of the springs by hand.
also the dampening is set to full stiff
Old Apr 29, 2010 | 07:32 AM
award78's Avatar
Try reading this thread: https://www.s2ki.com/forums/index.ph...ic=263345&st=0
Make sure the nut on the shock shaft is tight or not too tight. Could be a bad pillow ball bushing or bad shock. If all else fails contact ARK.....actually I'd contact ARK first then troubleshoot.
Hows the handling otherwise?
Old Apr 29, 2010 | 09:25 AM
GyozA's Avatar
Did it happen only after the coilover install or was it before too?
RJayRain
16
May 23, 2011 05:55 AM
Nick.
Dec 17, 2010 12:51 PM
Rdragon
May 6, 2010 08:05 AM
rich337
Oct 4, 2005 11:56 AM
speeeding
Feb 13, 2002 04:16 PM
