Sponsored by: Sake Bomb
koni yellows...
Old Mar 26, 2010 | 01:01 PM
S2KCER's Avatar
Default koni yellows...
hey guys, my rear right strut is damaged ( using amuse S tire spec dampers ) and i cant just buy a single from the factory, so i gotta swap out the two struts in the rear cuz i plan on reusing the springs which are teins springs at 14kg each. was wondering if koni yellows would be compatible with those springs? if not..what is my best alternative aside from getting another set of amuse dampers...any help would be appreciated thanks a bunch!!
ken
Old Mar 27, 2010 | 09:04 PM
JDMQuip's Avatar
You can use what ever springs you want with Koni Yellows. If the spring fits on the S it will fit on the Koni's.
Old Mar 28, 2010 | 08:38 AM
RT-B2's Avatar
Incorrect.
I purchased a set of Comptech sleeves and springs, designed to fit OEM struts, did not fit my Koni's. I later sold them.
Sebring AP1
Apr 9, 2013 08:46 AM
Buntinboy9
May 15, 2012 01:46 PM
s2kbtheway
Jul 24, 2011 02:27 PM
Gatsbee13
Dec 27, 2007 03:40 PM
