Sponsored by: Sake Bomb
KW V3 installation Question
Old Jan 8, 2012 | 06:49 AM
jelanier's Avatar
Default KW V3 installation Question
I have just ordered the KW V3 coilovers. While looking at the service manual, I noticed a special tool. (07MAC-SL00200) Do you need to do this for the installation?
Jim
Old Jan 8, 2012 | 06:59 AM
wrecked's Avatar
I didn't look up what tool that is but you will need to remove the OEM strut tops which requires a spring compression tool or buy new OEM strut tops to put on the new coilovers.
Old Jan 8, 2012 | 07:05 AM
dc2-2-ap1's Avatar
No, you do not need to separate the ball joint to remove or install oem or aftermarket coilovers.
s2000ellier's Avatar
You won't need a spring compressor to remove the top hats on the stock suspension just lay it on the floor, put the top hat against your wheel that you took off the car and remove the nut with a wrench. It helps to stand on the shock to keep it from moving when you relieve the tension but even then it barely moves as the spring isn't under great tension.
I used this method when I installed my KW V3 and it worked fine.
Old Jan 8, 2012 | 08:16 AM
Rubn1out4GudLuk's Avatar
S2ki KW V3 Install DIY
Old Jan 13, 2012 | 03:03 PM
drew313's Avatar
I noticed that too in the service manual although everyone removes the A-arms instead. Does anybody have any idea why the manual would call for removing the ball joint instead? There must be a good reason why the manual would recommend that method.
Old Jan 16, 2012 | 08:44 AM
Honestly, I think that's the "engineers way" to do it. As we all know, the engineers way is always more complicated and sometimes there's a simpler "mechanics way".
wcs2k
Apr 4, 2016 12:56 PM
ascoo
Jan 10, 2013 08:40 AM
chrispayze
Jun 26, 2011 08:30 AM
stylinhonda
Mar 30, 2009 11:35 AM
nzouk77
Feb 6, 2008 11:41 AM
