Sponsored by: Sake Bomb
lowering my s2000 help!
Old May 11, 2012 | 12:49 PM
bsaintclar's Avatar
Default lowering my s2000 help!
I have an ap1 i put for function type 2 coil overs on. i have the rear at the lowest setting and they sit up way to high! like almost a 2in gap from wheel and tire the front i was able to slam no problem and had to raise up from the lowest setting anyone else have this problem?
Old May 11, 2012 | 04:27 PM
05thumper's Avatar
These have two adjustments correct? Thread that goes into the lower collar and preload adjustment? You have both set on the lowest settings?
Sorry, not much help I guess. The rears are pretty simple and don't require much to preload since you don't remove any a-arm parts.
Old May 11, 2012 | 07:33 PM
savages2k's Avatar
dang im planning on buying these and the seller said they go low. hopefully that isnt the case here.
Old May 11, 2012 | 10:14 PM
kmac's Avatar
Let them set in, i have about an inch gap on mines
Old May 12, 2012 | 11:44 PM
savages2k's Avatar
an inch gap on the lowest setting in the rear??
Old Jun 3, 2012 | 01:16 PM
bsaintclar's Avatar
http://www.flickr.com/photos/8003568...in/photostream
Old Jun 6, 2012 | 09:42 PM
savages2k's Avatar
Did you get it that low after you messed with pre load? And do u go to sac state that parking garage looks familiar..
Old Jun 7, 2012 | 12:17 AM
Arthas's Avatar
Did you put the fronts in the rears, and vice versa?
rwedancr
Apr 20, 2012 12:01 PM
mikoZ
Jul 11, 2009 11:28 PM
96_LXR
Jun 5, 2005 09:16 PM
Never Quit
May 19, 2002 05:10 AM
