Moddiction front adjustable sway bar. 1.25" solid steel bar!
Former Sponsor
We are now offering a front adjustable sway bar.
We used to carry the Saner sway bar but that company is no more.
We have teamed up with a new shop to make these front sway bars. They are available exclusively through Moddiction.
We only offer these when in stock so they ship right out from Moddiction.
They will be available to order within a day or two at most!
We currently have 6 bars in stock and just double checking a few things before releasing them.
We will be doing another production batch of these shortly as well.
They come complete with hardware and custom end links.
3 way stiffness adjustable.
1.25" solid steel sway bar.
Bar weighs approximately 21 lbs.
Black powder coated finish.
Lifetime warranty on bar and hardware against functional defects to original owner. (All shipping costs to be paid by customer)
Made in the U.S.A.
http://shop.moddiction.com/Moddictio...ay-bar-068.htm
Sway bar specs:
OEM Honda front sway bar. 295lbs
Moddiction sway bar settings:
Soft setting. 566 lbs
Middle setting. 644 lbs
Stiff setting. 739 lbs
Made in the U.S.A.
Sway bar specs:
Former Sponsor
If non staggered this is a huge benefit. Especially AP1's.
When you run a non staggered wheel and tire setup say 255's all around you lose the grip advantage from the rear compared to when you would have say a 225 tire up front and 255 in the rear. So that would tend to make the car more prone to oversteer. Adding the front sway bar can eliminate that and then some.
