Need Help- Rotora Mini Big brake kit Calipers
Guys,
I'm interested in the Rotora mini big brake kit calipers that fit on the OEM size rotors. I contacted Rotora because I want to use my AP2V1 wheels. I needed to know if they will fit with any spacers. They came back with the following.
Can someone decode this in plain english as to what size spacers I need for AP2V1 wheels? Do I need anything else?
WHEEL CHART
A (MM) 35
B (MM) 170
C (MM) 98
WHEEL CHART
A (MM) 35
B (MM) 170
C (MM) 98
what its saying is that the front of the caliper is 35 mm away from the front of the disc, the caliper itself is 72 mm tall and from center to top of caliper is 170 mm.
hope this helps. i do not know what size spacers if any you will need
Originally Posted by TrackStar,Feb 22 2010, 11:04 AM
Do a search. I thought you would need like a 20mm spacer. Definitely will need something though.
basically they're showing you values that you need to calculate clearance for whatever given wheels you may use.
unless you have some cool 3D measuring device you're going to need a couple or straight edges and an extra set of hands will help.
(A) is the distance between the mating flange of the rotor hat to the outermost point of the caliper. So the 35mm they gave you is the total distance between where the wheel mounts to the rotor and the outermost point of the caliper.
Originally Posted by S2S,Mar 23 2010, 04:39 PM
your absolute minnimum spacer thickness would have to be 15mm
so example, if you take your second measurement and find that the 37mm mark (remember 37mm already accounts for the min 2mm clearance) is 15mm past the inside edge of your wheel spoke then you will need a 15mm spacer, if it's 25mm past then you'll need a 25mm spacer, etc.
S2000_Europe
18
Jul 17, 2007 09:22 AM
