Sponsored by: Sake Bomb
Ohlins DFV Clunking
Old 04-24-2019, 08:01 AM
JagoBlitz's Avatar
Default Ohlins DFV Clunking
Hello,
I am running Ohlins DFV with Sakebomb Lower Fork and 10k springs and 12mm preload in the rear.
I have a clunking sound when cornering hard. Top hats are torqued and bushings are clocked.
I occasionally heard this sound also with the 8k springs before, but now it is louder and more frequently (upgraded to 10k springs yesterday).
I suspect that the springs are moving and some kind of stick slip effect is causing the noise, but I would like to know if anybody else ever heard of this problem.
Thanks guys.
JagoBlitz
Old 04-24-2019, 08:29 AM
roel03's Avatar
Make sure damper to tophat is properly torqued.
Old 04-24-2019, 08:33 AM
flanders's Avatar
I haven't heard about that, are you sure it's from the springs?
Maybe check droplinks and all the ball joints for play.
Old 04-24-2019, 10:06 AM
JagoBlitz's Avatar
Tophats are torqued.
Sway bar end links were already replaced.
It seems to be worse than before with the stiffer springs...that is why I think it is the damper...
Something is suddenly moving or unloading and makes a single pop or clunk. Sounds metallic.
Would the bushings make a sound if they were not properly clocked or would they just silently wear faster?
Old 04-24-2019, 11:11 AM
cenix's Avatar
I would check the top hat bearing, that could be bad.
Old 04-24-2019, 12:10 PM
noodels's Avatar
Tried a softer damper setting.
Better or worse?
could even undo full on rear damper and bounce back of car<by hand>any noises?
ps when I replaced the links I got a noise<I did not torque one up enough>
Old 04-24-2019, 01:42 PM
[DELETED]'s Avatar
Mine have done something like this. Afterwhich the steering wheel is off center. If I go rip some high G turns, it clunks again and straightens out.
Old 04-24-2019, 02:46 PM
B serious's Avatar
Received 1,251 Likes on 947 Posts
Sounds like a massively safe situation you've got going on
Old 04-24-2019, 02:47 PM
B serious's Avatar
Originally Posted by JagoBlitz
Hello,
Thanks guys.
JagoBlitz
Do you still have the stock shocks? Can you try and swap those in?
Old 04-24-2019, 03:30 PM
noodels's Avatar
Quick Reply: Ohlins DFV Clunking
