Alignment issue
Alignment issue
I'm lowered from the floor to top of the fender 25 7/16" in the front and 25 9/16" in the rear. I was able to get -3 camber and .15 total toe in, in the rear but only -2.15 in the front with 5.35 degrees of caster and no toe. Does that sound right? I thought we could mess with caster to get more camber in the front but it didn't change. What are we doing wrong?
Also, I track my car on the local Gokart track (mix between autox and track) with a 255 square setup about once a month. This is also my daily driver. Should I spend the money for the camber ball joints or would the daily driving even out the tire wear? I was hoping for even tire wear and optimal performance. If I could save on the camber ball joints than I can put the funds towards a front sway bar.
