Sponsored by: Sake Bomb
Optimal ride height?
Old Mar 5, 2012 | 12:55 PM
cinaibur's Avatar
Former Sponsor
Default Optimal ride height?
My coilovers will be here Thursday, and I'm trying to decide how low I want to go. I remember seeing a hub centerline to fender measurment for optimal ride height, but I can't find it. I want the car to look good, but don't want the drop to be detrimental to handling.
Old Mar 5, 2012 | 03:28 PM
macr88's Avatar
Optimal depends on coil over type, spring rate as well as roll rate.
Old Mar 5, 2012 | 04:35 PM
cinaibur's Avatar
Former Sponsor
Well maybe not optimal, but is there a zero barrier I shouldn't cross?
Old Mar 5, 2012 | 05:20 PM
xredjar's Avatar
Two fingers between the fender and tire is a good rule of thumb. If you go too low and limit the amount of travel, you will hurt the handling.
Old Mar 5, 2012 | 05:23 PM
macr88's Avatar
14f 14.5r should be ok for most
Old Mar 7, 2012 | 12:42 PM
XtC-604's Avatar
read the manual or call/email the manufacturer. KW for example gives you a range for optimal performance of their coilover.
Old Mar 8, 2012 | 08:42 PM
ungucpho's Avatar
set the ride height and get it corner balanced. Just because it looks even does not mean the cross weights are set correctly
Calamari
Aug 11, 2014 12:46 PM
hamy
Jul 30, 2011 08:45 AM
Whoabitchin
Nov 28, 2010 11:12 AM
cvedral
Jun 13, 2010 08:42 PM
kevsS2
Nov 26, 2003 02:46 PM
