Sponsored by: Sake Bomb
Preload suspension
Old May 28, 2013 | 05:54 AM
joeskinny144's Avatar
Default Preload suspension
How do I preload my suspension? I have read about so many different ways to do it. what is the correct way to preload?
Old May 28, 2013 | 08:22 AM
icantbeseen1's Avatar
place a jack at the bottom of the suspension (which ever corner your on) jack it completely until the car comes up off the jack stand ever so slightly. than tighten all the bolts and move on to the next corner.
Old May 28, 2013 | 09:27 AM
arsenal's Avatar
For the front, I placed a jack under the brake disc and slowly raised until the frame rail lifted off the jack stand on the corner I was raising.
For the rear, the jack mounted perfectly in the lower ball joint perch (the threaded part did not touch, the lips wrapped around the hub point), then raised again until lifted
Old Aug 25, 2014 | 05:55 AM
Slowcrash_101's Avatar
Do you have to loosen all suspension bolts before preloading or just the ones you removed?
Old Aug 25, 2014 | 06:01 AM
iamxpl's Avatar
loosen the three 17mm bolts 2x upper brackets and the main one connecting shock to LCA. assuming only the upper control arms were removed for install. ideally youd want something in the driver seat with your weight on it. was anything else taken off?
Old Aug 25, 2014 | 06:47 AM
Nope I just removed the uca then I reinstalled all bolts jacked up the control arm until it lifted off the jack stand and tightened to specs. I went from lowered on coilovers to oem if that makes any difference. It just seems like I have excessive ride height. I haven't aligned the car yet I have an appointment for Wednesday.
Old Aug 25, 2014 | 06:53 AM
V6 Donut's Avatar
I'm guessing your talking about preloading the bushings right?
Yes.
Old Aug 26, 2014 | 05:15 PM
Apex1.0's Avatar
All the bushings need to be loose, and the car sitting at ride height. Then tq to spec. If you are changing ride height, you should tq all of them.
I have also taken measurements and found jacking one wheel at a time is not accurate. The best way to do it is to let the cars weight load the suspension to ride height. I drop the rotors on jack stands.
Old Sep 26, 2014 | 12:39 PM
S2K Al's Avatar
Exactly. I've only ever read one (correct) way to pre-load bushings, which is the way that is being described in this thread. Somehow, I think the OP is talking about the preloading of the coil springs, about which there is massive misinformation and myth out there.
Snakecharmer
Dec 1, 2015 04:28 AM
dsthez
Oct 16, 2013 09:45 PM
Bassoctopus
Feb 25, 2011 08:19 AM
BELGIUMPAUL
Jun 8, 2005 01:19 AM
allenheathdj
May 30, 2004 04:16 PM
