Sponsored by: Sake Bomb
Preloading?
Old Oct 15, 2013 | 06:07 PM
dsthez's Avatar
Default Preloading?
Can I just tighten the bolts of the suspension with the car on the ground (no jacks involved). I can reach under and tighten them. Ive done this before but is it the same effect as the four jack stands method?
Old Oct 16, 2013 | 05:40 AM
chino101's Avatar
Yes, pre-loading the suspension prior to torquing of the suspension bolts accomplishes that same function as the method that you mentioned. However will you have enough room with the car on the ground to generate the appropriate amount of torque to tighten the suspension bolts to specifications?
Old Oct 16, 2013 | 06:30 AM
dsthez's Avatar
Yes plus you can still take off the wheel again to give the bolts that extra half turn when your done.
Old Oct 16, 2013 | 09:45 PM
NFR_AP2's Avatar
That sounds like too much work IMO. Just use two jack stands and do the front then the rear. If you have 4 jack stands even better.
joeskinny144
Sep 26, 2014 12:39 PM
Bassoctopus
Feb 25, 2011 08:19 AM
BELGIUMPAUL
Jun 8, 2005 01:19 AM
rlaifatt
Mar 31, 2005 09:16 AM
allenheathdj
May 30, 2004 04:16 PM
