Sponsored by: Sake Bomb
question about my alignment
Old Jun 21, 2010 | 01:43 PM
sillyboybmxer's Avatar
Default question about my alignment
went to get my uk spec alignment and the tech said he cant get my front toe set to 0 when its at -1 camber, the only way to set the toe to 0 was to increase the front camber to -2. he could get the the rear almost spot on but he said my tie rods were maxed out on the adjustment. does this sound right??? or is he a noob?? i am dropped to no finger gap in the front. but it does handle not on par of what i was expecting,...im thinking its just the camber being so close front and rear. should i have the rear changed to -3 ?????
Old Jun 22, 2010 | 08:18 AM
Mintifresh's Avatar
Arent you also on the softest setting on the n+?
Also -3 outback isnt bad. I am right at 3.2 right now.
Before you decide that its the allignment , play with the dampers as well.
Old Jun 22, 2010 | 08:58 AM
i was on the softest all around, then last night i stiffened the front up to 10 clicks from soft and left the rear alone, it did handle A TON better. way more solid. Probably move the rear to 5 clicks in or so today i check it out.
madness
Feb 14, 2011 03:50 PM
agent
Oct 2, 2008 02:02 AM
S2K:-)
Apr 13, 2006 08:31 PM
RazorV3
Nov 14, 2004 08:18 AM
