Sponsored by: Sake Bomb
Rear crossmember question!
Old Aug 30, 2012 | 12:38 PM
bbs2z's Avatar
Default Rear crossmember question!
Hi guys so I was involved in a little accident a few months back and the car was repaired fine and the alignment was done, the accident was on the right rear starting at the door and ending at the wheel, pretty much someone pulled on me while I was driving and bent my door, quarter panel and rr wheel got damaged. So the other day I was observing my car and noticed my right rear wheel sits more back then my left rear wheel by half an inch, so I took the car to a local shop put it on the alignment rack and noticed my crossmember is shifted back on the right side, the toe and camber angles are in spec but my question is that can the crossmember be adjusted to fix the caster geometry in the rear? Please help!
Driver side
Passenger side
Passenger
Driver
Old Aug 31, 2012 | 10:45 PM
bbs2z's Avatar
Nobody knows if it has any adjustment room?
Old Sep 1, 2012 | 11:42 AM
99SH's Avatar
The subframe can shift under impact. Loosen the 6 subframe bolts and position to spec. This is very basic stuff, any decent alignment shop that's willing, should be able to do this.
Old Sep 2, 2012 | 12:47 PM
bbs2z's Avatar
Ok thank you very much just needed to know if it's adjustable or if I need to put it on a frame machine
Vtec dpn
Dec 11, 2018 02:44 PM
TPhong
Mar 11, 2013 07:02 AM
TPhong
Jan 18, 2013 07:28 AM
Lummie
Jan 23, 2011 01:24 PM
tinkfist
Jun 7, 2007 12:36 PM
