Rear pads wearing a lot faster
How did that wheel spin, was it relatively free?
My guess is the caliper is binding a bit, why'd you need to replace the pin? The binding might not be a lube issue but more of a fit issue, possibly too loose?
It was free both in and out of gear, whereas both wheels spun freely in gear. I guess I should put the rear up in the air, step on the brakes, and see if it still spins freely
Well I had two Pin As in the drivers side caliper when there was suppose to be Pin B on top and A on bottom. Not sure why though.
The pin shafts? If so, then yes. Had to glob up the tip and dump a few iterations of grease into the boot with the pin itself. Otherwise the boot would just scrape it off. Anyway, new Pin B installed and lubed. New brakes feel so good. Off to the track tomorrow!
Be careful with how much you lube the pins. The pad may have worn poorly after install due to too much grease and once they wore enough to move the caliper away they probably started to wear normally but the damage was already done.
went through the brand new pads in two days
after day 1
Attachment 194961
midway through day 2...glad I brought my old pads...another S running OEM pads had the same thing happen, so Im glad Im not the only one
Attachment 194962
Attachment 194963
after day 1
Attachment 194961
Attachment 194962
Attachment 194963
amen brother...Carbotechs next season fo' sho'
